820 inner axle nuts
toolz
03-30-2008 21:39:56
Got my 820 differential back together today. Had to make a shim to tighten it up, and had to make another shim to set the bearing end play, but it's together now.
I wanted to button up the rear end also, and thought I should check the axle end play. The right was pretty loose, and when I tried to tighten the inner nut, it was stripped. Hardly any threads left in it. The left nut is OK, but it's wrong for the tractor. It doesn't have the machined relief on the face to go over the axle splines, so it won't tighten the axle up. I need two nuts badly, part number R27R. I'm going to check with Deere in the morning, but I'd be surprised if they are available. Can anyone healp me out? I'd take new or good used. Thanks for your help- Kevin
