Deere 720 and 730 value/ cost of repair
Farm W/Junk
03-30-2008 18:19:17
Hi i just purchased a deere 720 diesel pony start sight unseen. It has factory widefront and 3 point tin is straight, not rusty. Tires are 50%. Pony and diesel run but pony needs carb rebuilt and the deiesl the cam idler gear is out and partially disassembled. What is the value of the tractor as is and the cost to fix it. Also what is a nice 730 diesel electric start worth? narrow front, 3 point, clamshell fenders, perfect tin and grills, 50% tires 265 hours on meter. Thanks Matt
joelrand
04-04-2008 09:31:50
 Re: Deere 720 and 730 value/ cost of repair in reply to Farm W/Junk, 03-30-2008 18:19:17
I am getting ready to put the gauges in and start mine for the first time in 4 years. That"s how long it took for me to completely tear it apart, paint each individual piece, fix or replace whatever was broke. Now I"m broke. But, the education I got doing everything myself was well worth the expense. I paid 2,000 for it in a nonrunning, rusty but complete condition. I have used JD parts where that was the only option, repo elsewhere. Probably 4,000 dollars and equivalent hours in it.
buickanddeere
03-31-2008 05:28:12
Check the flywheel for being loose. Most tinkerers didn't understand they needed a torque wrench. Too loose = ruined splines. Too tight and the bolts would stretch= ruined splines.
Mike M
03-30-2008 18:38:34
It's most value is right now before you spend anymore on it. Once you decide to fix it if you do it right you have to make a full commitment to do what ever it takes and realize you won't make any money on it , but will enjoy the satisfaction of a job well done. I completely went through mine in 1985-1986 and spent $5,000 in parts. You can easily triple that figure for todays high prices.
