2010 with 46a loader hydraulic question
DenT
03-30-2008 16:31:11
Have friend with a 2010 and 46a loader he is putting on tractor. Does anyone know where his remote two spool valve should be plumbed to?
He tryed hooking up to rear tractor outlets but this will only work when lever on dash is moved.
Is there a way to hook up directly to hyd. pump or maybe under dash somewhere so he has constant oil and return from his remote valve?
Thanks in advance for any help.
robersw
04-05-2008 18:18:27
 Re: 2010 with 46a loader hydraulic question in reply to DenT, 03-30-2008 16:31:11
Thanks, that will be great.
robersw
04-02-2008 05:38:02
edj856
I would also be interested if you were able to supply that part number for any of my future 2010 needs.
Thanks
edj856
04-05-2008 12:42:01
 Re: 2010 with 46a loader hydraulic question in reply to robersw, 04-02-2008 05:38:02
The part no. for the cover plate on the remote control valve assembly for use with a loader is C 14656C - Cover, outlet. I will try to post a picture of the parts diagram in the next day or two.
edj856
04-01-2008 10:00:31
To plumb the loader without going through the remote valves at the back of the tractor you have to replace the top plate for the actual remote valve (the parts diagram on this post). There is another no. 3 that has outlets to run the loader with. I can find out the part no. if you want, it is in a 36A loader parts manual. It is no longer available from Deere and no dealer has any old stock (I'm trying to mount a loader on my 2010 also). A good machine shop may be able to fabricate the top plate you need. Another option is to run a hydraulic pump off the front crankshaft pulley like on a 2010 industrial, but there is not much room at all.
DenT
03-31-2008 05:18:47
Thanks for the comments. If he just ties the lever down on the dash doesn't that just put pressure out to his Two spool valve that runs his loader. Where does the return oil go when he releases the spool valve? Since it is a open spool valve when the oil flows thru it it has no where to return at the rear tractor outlet unless he moves the lever on dash to the other position.
The pump makes a lot of noise as it is pumping against a closed loop. I would think that would not be too good for pump. Just thinking out loud. Any comments? Thanks again.
Bob
03-31-2008 10:22:21
 Re: 2010 with 46a loader hydraulic question in reply to DenT, 03-31-2008 05:18:47
There's TWO hydraulic couplers at the back, right?
(Or does the 2010 have a single acting, one-couple option?)
ANYHOW, if he has two couplers, a hose from one will go the the loader valve's inlet port, and the hose from the other will go to the loader valve's "return" port.
If you tie the dashboard lever back, and note which coupler gets pressure, and make sure that's connected to the loader valve's inlet port, the setup SHOULD work.
DenT
03-31-2008 16:25:01
 Re: 2010 with 46a loader hydraulic question in reply to Bob, 03-31-2008 10:22:21
BOB There are two couplers on rear of tractor. Will check to see which way hoses are hooked up to his spool valve. Will reply after trying this. We do have both hoses hooked up now but don't know which way they are. One quick question. When lever on dash is locked down, does this push oil out one coupler and open a return path thru the other coupler to the resivoir? Or do you have to move lever in other direction to allow oil to return back into resivoir? Thanks
Bob
03-31-2008 17:15:57
 Re: 2010 with 46a loader hydraulic question in reply to DenT, 03-31-2008 16:25:01
Leave the lever tied in one direction. ONE coupler will feed oil OUT to the loader valve, the oil will return to the tractor through the other.
The big thing is to get the oil coming FROM the tractor plumbed into the "inlet" side of the loader valve. If you reverse the connections, the seals on the loader valve spools will be exposed to the full hydraulic pressure from the tractor AND the relief valve in the loader valve can't work (although it should not need to, since the tractor has it's own hydraulic relief).
I have NO way of knowing WHAT loader valve you have... open center, closed center, or one that can be converted to either.
HOWEVER, this tractor IS an "open-center" system, and the loader valve MUST be "open-center", as opposed to the Waterloo tractors which are the opposite, and need a CLOSED-CENTER valve.
DenT
03-31-2008 17:30:47
 Re: 2010 with 46a loader hydraulic question in reply to Bob, 03-31-2008 17:15:57
Bob Thanks for all your help. Will check it out with my friend and see what his valve is.. Thanks again.
thurlow
03-31-2008 05:43:26
No matter where you get your oil supply from (and return it to the tractor), your 2 spool valve will HAVE to be set up with the correct end cap, i.e., one for a closed circuit system. I assume (I know about assumptions) the 2010 is closed circuit like the larger John Deeres of the era. If the valve is set up for an 'open circuit', the oil will quickly overheat and the tractor's hydraulic system will fail. Maybe Bob or one of these other gurus can explain it better..... ..
Bob
03-31-2008 10:17:29
 NO worries... 2010 = OPEN CENTER. in reply to thurlow, 03-31-2008 05:43:26
NO worries... 2010 = OPEN CENTER, unlike it's Waterloo cousins.
thurlow
03-31-2008 06:00:56
 Re: 2010 with 46a loader hydraulic question in reply to thurlow, 03-31-2008 05:43:26
Closed center, not closed circuit..... ..
Bob
03-30-2008 23:23:34
I've HEARD there's supposed to be a way to do "power beyond" from the hydraulic valve area in the steering pedestal, but don't see the parts to do it in the on-line parts book.
There are some serial number variations in that hydaulic system, as well.
Third Party Image
A peek inside a genuine DEERE service manual (which I DO NOT have) would give a more definitive answer.
A friend has used his 2010 witha Du-Al loader for YEARS by tying back the dashboard lever, and running hydraulic lines from the rear remotes to the 3-spool loader valve.
Here's a photo of the 'ol girl this past fall, unfortunately with the loader "off".
Third Party Image
I know he put it back on an moved snow with it this winter, but UNFORTUNATELY,no pix at this time!
thurlow
03-30-2008 19:13:08
Can't answer your question..... know nothin' about 2010, but why not just tie the remote lever..... .one way or the other, depending on how the hoses are plugged in?
