3020 steering locking up
Jeff Oliver
03-30-2008 13:29:00
I have a 3020 gas and sometimes the steering will lock up. If you turn the wheel to the left and back it will usually unlock and go on. When you start it up you sometimes have to turn the wheel to the right and wait until the wheels go all the way over to the stops before it will steer. What causes this? How can it be fixed?
Thanks!
LarrySTN
03-30-2008 20:55:01
 Re: 3020 steering locking up in reply to Jeff Oliver, 03-30-2008 13:29:00
This problem can be caused by either the steering valve or the steering motor (cylinder set up front) or both. A quick test is to open the right radiator screen and plug the lines where the connectors are. This needs to be done with the proper jic fitting plugs. The plugs need to be on the lines coming down. Start the tractor and try turning the steering wheel either way slowly, if it will slowly continue to turn, you will need to rebuild the steering valve. If not then rebuild the steering motor.
msb
03-30-2008 19:14:29
Steering valve is out of adjustment. Have it rebuilt. Should take about 2-3 hours labor once its out of the tractor. Where do you live?
Bob Bancroft
03-30-2008 17:36:07
It's the incredibly over complicated over sized "valve" under the dash. I've fought the same thing in my old 4020 for years. It only ever bothers going to the left. I JUST put it back in after having another JD expert work on it. Now it doesn't lock up, but puts up some resistance going to the left, will spin freely to the right. I JUST today finished rebuilding the motor up front at his request before I pull the valve out again!(There was nothing wrong up front)
matthies
03-30-2008 17:52:00
 Re: 3020 steering locking up in reply to Bob Bancroft, 03-30-2008 17:36:07
Bob, I would adjust the valve again. Seemed like if a guy doesn't do one so often a guy looses his touch at adjusting. Seemed like some needed oil ran through them to seat everything and once adjusted again its good to go. Luckily the last two were out only once. The first one I did at the dealership went good until my boss said to always replace the plate between the two housings because they crack. Sure enough it was, toward the bottom of the center hole for the tube/threaded shaft. Had a friend who had one internally cracked cause he never could get it to work. chris
Ronnie Langford
03-30-2008 17:05:31
Probably one of the cylinders at the front pedestal is by-passing hydraulic oil.
