2940 intermittent start
David S.
03-30-2008 12:15:44
I have a 1980 2940 that the starter cranks intermittently. I put a new starter(high torque from DB electrical) and when it turns over spins it like a top and engine starts in 3-4 revolutions. Ive taken voltage readings and when its not cranking it gets about 9-10vdc at the seliniod and starter(with key held in start position). Good batteries, new key switch, and tried changing relays. Thought maybe bad ground, what do you guys think?
HeyPigFarmer
03-31-2008 05:11:39
 Re: 2940 intermittent start in reply to David S., 03-30-2008 12:15:44
Don't know if this relates to the new starter or not, but our neighbors 2940 eats solenoids. It will click with the key but you can (I know you aren't supposed to) but you can get it to go by using a screwdriver between the terminals on the solenoid. He goes through one every 2-3 years.
buickanddeere
03-30-2008 18:32:26
Might be a dead spot on the Armature as previously stated. Some of those Delco gear reduction starters such as the MT29 and better yet the larger MT30 series have lots of cranking power.
If memory serves it's a 10 tooth pitch and 10,11 or 12 teeth. 12 is better with a high HP starter.
David S.
03-30-2008 15:27:22
When this occurs which is quite frequently, when you turn the key all you here is a bump or click from the starter. Then you have to short the selinoid just enough to bump the motor over, then the tractor will start with the key.
Mike M
03-31-2008 06:29:04
 Re: 2940 intermittent start in reply to David S., 03-30-2008 15:27:22
Sounds just like the problem with the lawn and garden tractor models. The wiring isn't heavy enough to carry enough amps to pull the solenoid in hard enough. They have a kit for the mowers to hook up a relay by the starter.
David S.
03-31-2008 13:07:47
 Re: 2940 intermittent start in reply to Mike M, 03-31-2008 06:29:04
Mike M Are you talking about the wiring to the selinoid or the battery cable to the starter. I was going to have a 2/00 cable made and run it from the starter mounting stud to the negative battery terminal to eliminate having to travel through frame to battery.
Mike M
03-31-2008 19:09:44
 Re: 2940 intermittent start in reply to David S., 03-31-2008 13:07:47
Nothing wrong with good heavy cables. I don't know if it will solve your problem , but the kit for the mowers just hooks to the solenoid. The way to test it is to by-pass the wiring by just jumping it at the starter. You can use an automotive tool that has clips on the wires and a push button this way you can still sit in the seat as not to run over yourself by accident. You may just have a solenoid problem ?
Woodbeef
03-30-2008 14:15:55
Check with your Deere Dealer for a kit they have for the earlier Mannhiem tractors to solve that problem. If I rember correctly it's a capacitor. I put one in my Steyr years ago,that had the same problem.
David S.
03-31-2008 13:11:27
 Re: 2940 intermittent start in reply to Woodbeef, 03-30-2008 14:15:55
Woodbeef
I will check with the local dealer, do they have to search for a technical service buliten through the service department or will the parts counter be able to find this.
44 Diesel Tech
03-31-2008 16:30:47
 Re: 2940 intermittent start in reply to David S., 03-31-2008 13:11:27
David. Mike M is right. Install extra solonoid/relay near starter. All 40 series need them. Had to do this many times when I worked for the dealership.
Howard
David S.
04-02-2008 14:44:03
 Re: 2940 intermittent start in reply to 44 Diesel Tech, 03-31-2008 16:30:47
44 Diesel Tech
Could you explain how i would go about adding the extra solonoid relay, are you talking about keeping the original and bring 12v in on a new line.
