2840 steering
Ronnie Langford
03-30-2008 10:00:47
Do these tractors have a history of power steering problems?
44 Diesel Tech
03-31-2008 16:37:29
 Re: 2840 steering in reply to Ronnie Langford, 03-30-2008 10:00:47
These steering valves almost always fail when cast grindings are present in the oil caused by brake failure. Howard
Bill Lisbon
03-30-2008 19:29:03
I worked on two in the last year, The steering wheel goes around by itself. Found dirty oil in both of them, probably from the brakes. Rebuilt one steering motor, had to replace the other.
buickanddeere
03-30-2008 15:14:31
After 30 years time and 10 of thousands of steering wheel motions. The seals in the column can start to seep. Not a panic issue nor a chronic problem. Seals under wear, pressure and time will all leak sooner or later.
Mike M
03-30-2008 11:25:18
I always thought of them as a larger version of the smaller models. All these JD's with closed center systems are good , BUT neglected maintenance and using discount oils will kill them. Brake facings go bad and then metal gets all through the system and then you will always seem to have problems. So a good one should stay good and a bad one will become a nightmare.
