B John Deere
sam in mo
03-29-2008 18:36:05
On a 1950 B that a friend just traded for it has two levers on the colum. One is for controll of the speed of the eng. What is the other one for? I told him it was a overdrive, I think he beleived me. Thanks in advance for any help. Sam
CLW
03-29-2008 21:25:54
 Re: B John Deere in reply to wilamayb, 03-29-2008 18:36:05
The water pump did not come out on the B until serial number 306600. That was in the later part of the 1952 year model. At that time they put out a retrofit kit to add the pump on any B back to the first late model built, 201000. The B went to a Distributor at serial number 268820, but, as mentioned above, you could still get a Magneto if you wanted. The choke rod was moved from the dash to behind the steering support at 258520, in early 1950.
d. coleman
03-29-2008 20:20:32
 Re: B John Deere in reply to sam in mo, 03-29-2008 18:36:05
the second lever was for allfuel models only. the lever was left in place on gas models and the radaitor shurters were not installed, as per green mag. my 51 "B" has the lever also. d. coleman
EdM
03-30-2008 19:43:52
 Re: B John Deere in reply to d. coleman, 03-29-2008 20:20:32
My 51 B gas has one and it's connected to the shutters.
F-I-T
03-29-2008 20:48:21
I'm pretty certain that they was always an option on the gas models, and a popular one at that. Our '48 "A" gasoline-engine-from-the-factory was equipped with factory installed shutters. Every A and B I was around in the colder midwest had shutters installed. Shutters were the only way to keep the temp up when doing light work like pulling a spreader in Ferbuary. Not enough load to keep it hot. Even gaslinie will foul plugs at 120* or less.
jd b puller
03-29-2008 18:43:00
That's to activate the NOS at the end of the pulling track.
Or maybe it's for front shutter controls. Never actually seen a working model or anything hooked up to it though.
B-maniac
03-29-2008 19:38:18
 Re: B John Deere in reply to jd b puller, 03-29-2008 18:43:00
That's funny, I always thought it was the torque amplifier lever.Maybe that was only on '51 or '52.
Buster
03-29-2008 18:42:35
The other lever is for the radiator shutters, most of them have been taken off over the years.
F-I-T
03-29-2008 18:41:02
Manual control of the front mounted radiator shudders. Since it didn't have a thermostat, that allowed you to regulate the engine temperature in cold times to keep the engine temp up where cleaner combustion could take place. Nice when you were hauling light loads into cold winter winds, too. Pretty much a requirement on the distillate burning engines. A lot of folks don't bother with them, and they tend to run the engines too cool and foul plugs at a faster rate.
HTH
Frank
