4240 loader tractor?
Nylon4020
03-29-2008 18:19:01
The local massey and bobcat dealer is begining to look like a john deere lot. A jd 4000 with a 48 loader on it and 3 other jd tractors with odd to me model #s. Lotta guys trading in older deere iron for new massey 4x4s. Anyway they now have a 4240 with a 158 loader on it. Wondering how these are as a loader tractor. Only drawback for me is that it is a 1000 pto only and it is dern expensive.
ccjersey
04-01-2008 19:42:21
 Re: 4240 loader tractor? in reply to Nylon4020, 03-29-2008 18:19:01
We bought one that had done a lot of loader hours, and the powershift shifter levers were all worn out. The PS transmission is not my favorite for loader work. I would rather have a synchro-range or a quad range to run a loader. Have done that with 4020's, 4320, (no hydraulics if you hold the clutch too long) and the 4230 quad range and 4440 power shift.
As I said, I would rather have the quadrange/synchro-range, but if hired help running it, the PS would probably last longer.
TractormanNC
03-30-2008 07:13:53
About 2 years ago I bought a 4240 quad range with a Bush Hog 3226QT loader. Good tractor but too big and bulky for handling 4x4 round bales and stacking in the barn. Transmission seemed awkward for shuttle work. Long and heavy on the front for field work too. Bought a 2750 and put a used Allied 595 loader on it. Good transmission for loader work. Made a great combination. 4240 is now used for field work only. BTW the 3226QT loader is almost new and is for sale.
Tx Jim
03-30-2008 04:26:37
 Re: 4240 loader tractor? in reply to fixerupper, 03-29-2008 18:19:01
Gerald you're correct in that the pto shaft can be changed to 540 but not by just turning shaft from one end to the other but by insering a 540 rpm shaft totally different from a 1000 rpm shaft. The 540 shaft should be stored at upper left of drawbar pointing endward from left rear wheel. I did own a 4240 with a 158 loader and it as a good set-up. Mine had joy-stick hyd controls.
Gerald Bennett
03-29-2008 21:49:34
Hello, I have a JD 4240 with a 148 loader. I would rather have the 158 you mentioned, there a heaver loader. The 4240 is a good loader tractor. About the pto, mearly take the snap ring out, pull the short shaft out, turn it end for end, put it back in, replace the snap ring, and you have 540 rpm. By the way, put the front of the tractor down hill so you don't lose too much oil when you pull the shaft out.
R. John Johnson
03-29-2008 20:46:08
I think you can switch the shaft and the differences in the shaft causes a gear shift in the transmission so that it turns at 540 RPM.
John
JMS/.MN
03-30-2008 08:14:30
 Re: 4240 loader tractor? in reply to R. John Johnson, 03-29-2008 20:46:08
The two shafts are different in that the location of the splines is different- one near the end, the other at the end. Doesn"t shift any gears in the transmission- just engage different ones in the rear end.
