Pay the man John. No push rod tubes in a '50'. Before you tear it down, drain the oil like you've done, and if you want, you can fill the radiator with some water, sometimes I put food coloring in it, apply some low air pressure, like 15 lbs or less, to the radiator, and look into the spark plug holes and into the rear through the top access cover plate over the crank. Let the drain plug out and put a bucket under there, and see if you can see how the water gets to the crankcase. If it comes past the pistons and rings, that points to a head gasket, and you might see that through the spark plug holes as well. If you see a major crack somewhere else, it can help you decide how far down it needs to be disassembled. Or, just bite the bullet and remove the head at a minimum. The block can generally be removed from the frame without no troubles, thought you might have to buy or build a 1 1/8" box end or crow's foot wrench to get the nuts off of the case to block studs. There are 8 nuts. i seem to remember that there are also two bolts into the block from the bottom through the frame casting. Remove the rod caps and remove the block with the pistons in it, at least that works best for me. It's a good chance that it's just a gasket issue, but you need to rule out cracks on 60 year old machinery. HTH Frank
