Babbit bearing torque and flywheel position screw
WeirdDeere
03-29-2008 01:00:06
I'm working on a '38 DI, and trying to find the D torque specs. I know I've got them in my piles of info and service bulletins. And it is eluding me in the I+T book as well. I'm tired.
BUT I've never had the privilege of working with babbitt bearings, this is both on main and connecting rods. I know the published values are for insert type bearings (which I know are much more picky about torque)...can these values be applied to the babbitt type? I would assume so since the bolts are the same, but I'd like to be sure.
Also, I think I need to find a new D1080R flywheel positioning screw. I mangled mine good when I forgot to remove it when pulling off the oil slinger. Yes, I'm dumb. Are there any sources for these?
Thanks,
Brandon
Duane Larson
03-29-2008 07:23:36
 Re: Babbit bearing torque and flywheel position screw in reply to WeirdDeere, 03-29-2008 01:00:06
Brandon,
Connecting rod bolts are 90 ft-lbs for the D - then continue to tighten to the next opportunity to put a cotter pin in the castellated nut. No torque values are given for the mains. The flywheel locating pin is just a 1/4-20 piece 0.500" long. I saw off a bolt to the proper length, cut a screw slot in it, and put it in place. The same pin is used on several other models.
WeirdDeere
03-30-2008 14:53:13
 Re: Babbit bearing torque and flywheel position screw in reply to Duane Larson, 03-29-2008 07:23:36
So is there any guide for how tight to go for the mains? Just as tight as it will go? Can I go TOO much? I doubt it, but I'd like to be sure.
Brandon
Duane Larson
03-30-2008 21:25:11
 Re: Babbit bearing torque and flywheel position screw in reply to WeirdDeere, 03-30-2008 14:53:13
Brandon,
Well, I'm sure with a long pipe you could stretch the main bearing bolts which would not be good. One thing would be to measure the bolt size and threads/inch, then look in torque tables for guidance. As I recall they are 9/16-18 (assuming grade 5), so I'd go to 120-125 ft-lbs, then continue to the next slot for a cotter pin.
DJD-Man
03-29-2008 05:49:44
Can't help you there but do enjoy following the long story on the DI. Looking good, keep it up. How's the 80 coming along? Thanks for posting on that also.
