4640 d range
Moline_guy
03-28-2008 21:49:02
Does it do any more damage to a transmission by continuing to run a 4640 quad without a functional d range? A,B,andC work fine, does not move at all in D. Heard of guys continue to run them when one range goes out. Thanks for any replies.
Moline_guy
03-29-2008 21:35:21
 Re: 4640 d range in reply to Moline_guy, 03-28-2008 21:49:02
thanks for the replies, figured there was no yes no answer. My brother bought it an auction the other day, he thought it was cheap horsepower, he knew about the d range and owners said its been that way for a while. It came with a dozer and he gave 10,000 for it. He will definately change oil and filters, am guessing he will run it for springs work right or wrong, maybe this fall or winter we can tear into it. Thanks for your replies.
mattd
03-29-2008 16:44:08
is it an adjustment probelem? how much metal pieces were in the filter and sump screen? the transmission pump pumps unfiltered oil so any metal goes through the pump. well the sump screen is the only filter for the pump but the pump can still be damaged. if the splines broke off the d range gear or somthing like that then just pull the cab and cover off transmission and clean the metal out and then it will be ok to run. not tryin to be a smart$@# but you will eventually do damage. its gonna be cheaper to fix it now
HeyPigFarmer
03-29-2008 05:20:41
Depends on what is broke in there. If you look at enough ads there are guys that say "B has been out for 6 years but still works in the rest" or something along those lines. I don't like taking a chance like that though.
