Can't get it started JD B
Roger Stanton
03-28-2008 15:49:00
I am restoring a 1940 John Deere styled "B" and have replaced the pistons and rods, reground the crankshaft, ground the valves and rebuilt the carb..I did not do anything to magneto or govenor... It won't start.... does anybody have any ideas?
Big Country - IL
03-30-2008 14:22:26
 Re: Can't get it started JD B in reply to Roger Stanton, 03-28-2008 15:49:00
make sure it is getting good spark on both sides...and that its getting fuel...after I rebuilt my first B, I wasted an afternoon trying to get it started when it had a "grease" plug in the three way valve...2 people (as mentioned by someone else) is a good idea too...
johns48jdb
03-29-2008 17:44:21
lets see how big of a stink i can raise here. remove a plug and put a tiny bit of either in it and replace the plug quickly and snug it by hand and turn it over if it fires y0u've got carb problems. it might even take off running. my 48 hadn't been cranked in a while and i put a tiny bit in it and off she went. everybody please note tiny bit. please be gentle with replys.
Sam from WA
03-29-2008 12:49:08
I've got a wisconsin VE4 V4 engine that wouldn't start after we did a valve job. We found the trick was to have more than one person crank the thing over, and when one guy got tired, the next guy in line took over. The engine now starts on the second or third time over, and the choke is fully closed for one full revolution and after that until the engine starts (2-3 pulls) the choke is half way open. The throttle is approximately 1/3 to 1/2 open. Once we got it running that first time, I can turn the engine real slow and the magneto will pop, and the engine will take off a runnin' (its gotta be warm).
It's kind of a trial and error system until you find the right combination of choke, throttle, and rotations of the flywheel.
Jon Hurley
03-28-2008 19:56:06
Oh how I sympathise with you. I got a '41 B about 2 months ago and had problems getting her started. It took new plugs and wires, drilling out the passages in the carb, replacing the hose connecting the breather with the carb elbow and some playing to see what she liked.
Here's how mine likes to start:
Open the petcocks, turn on the fuel, open the idle needle an extra half turn, open the throttle a touch, pull the choke lever back, then 2 turns of the flywheel (today only 1 and a 1/2 turns) and she fires right up. Then I close the petcocks and close the idle needle the 1/2 turn I opened it before starting.
Dandy Don
03-29-2008 16:21:45
 Re: Can't get it started JD B in reply to Jon Hurley, 03-28-2008 19:56:06
Jon, I saw your site and that John Deere with two engines is really something. Is it yours? Do you know the owner? It's a very neat tractor. What part of the country is it from? Thanks.
Don
johns48jdb
03-28-2008 19:26:06
try reversing the plug wires. i was told to time my 48 b to losen the mag, turn it all the way to the left and snug it there. turn the flywheel until the holes in it were parallel to the ground and then turn mag to the right until it snapped and tighten it down there. check your settings on your carb to where they are both open about a turn. one may have to be 3/4 while the other 1 1/2 open. if you open them to much you'll foul them. if you had gas blowing out of the sparkplugs holes the your oil in the crank case is probably diluted and you'll need to change it before you fire it up. one thing that always helps is to invite a sailor over to learn a few new words from him to use on it. good luck. keep asking if you don't figure it out. somebody here can help.
DanL-B36320
03-28-2008 17:13:07
 Re: Can't get it started JD B in reply to Nathan Fowler, 03-28-2008 15:49:00
Roger Stanton said: (quoted from post at 23:49:00 03/28/08) I am restoring a 1940 John Deere styled "B" and have replaced the pistons and rods, reground the crankshaft, ground the valves and rebuilt the carb..I did not do anything to magneto or govenor... It won't start.... does anybody have any ideas?
My 37 was stubborn when I first got it home last fall, (though it hadn't been rebuilt). I'd pull, and pull, and pull, and pull until I was out of breath, then have a cigarette (just kidding, I don't smoke), then pull some more. Most times, until I found the secret, it didn't fire, cough, hiccup, or even give any hint at all that it would EVER start.
Then, one day, I found mine is VERY sensitive to flooding, and flooding occurs quickly and easily. I discovered it when I pulled the plugs out, pulled the flywheel and fuel literally spewed out of the hole. That's when I learned that it doesn't like much choke. (I'd been choking it waaaaayyyyy too much.)
Since then, I've started it within 3 or 4 pulls by following a pattern:
1) It always begins with the shutdown; to shut it off, I turn off the fuel, open the carb bowl drain and let 'er run until she dies. This gets rid of any excess fuel in the carb and cylinders and is probably a better way to shut down any engine anyway.
2) When starting it, I fully close the choke, pull the flywheel through ONE cycle (both cylinders through the compression stroke), throttle half open, choke half open (or half closed, depending on your political perspective), and give 'er a pull. She nearly always at least coughs on that next pull, and will be running with only another one or two.
Not saying that's your problem, but you're going to have to experiment with what your old girl happens to like because just like most women that I've had the pleasure to know, they all like something that's just a LITTLE different than the others.
PBrowning
03-28-2008 16:59:10
Roger -- That first start can be a tough one, and most likely some little thing is the cause. Not having much background data other than the mechanical work you described, let's try to go back to basics here. And to that end,I am sending you to the JD-H site (below) and whence there, scan across to ARTICLES 2, and from the drop-downs, select LOSS OF POWER. While tailored for the model "H", the engine basics are about the same, and perhaps the read will jog your memory to check something previously overlooked.
There are a number of helpful articles you will find useful, so put the site in your favorites for now until you have your project completed. (PatB)
old
03-28-2008 16:03:25
First off I'm guessing its hand start. Do you have spark?? Does it spark at the correct time?? Does the impulse work, I.E. when you turn it over do you here the mag sort of click?? Not uncommon for one to be hard to start the first time or 2 after a rebuild. You might give it a pull and see what happens.
Roger Stanton
03-28-2008 16:13:54
 Re: Can't get it started JD B in reply to old, 03-28-2008 16:03:25
thanks for the quick response...yes it is hand start, yes it does spark and yes and I am pretty sure it sparks at correct timing and yes impulse does work...I still have some work to do before I can pull it...
old
03-28-2008 17:44:24
 Re: Can't get it started JD B in reply to Roger Stanton, 03-28-2008 16:13:54
The first time I started my 1935 JD-B after installing a new mag and carb on it plus got the engine unstuck I had to pull start it. I pulled it all of 10 feet and it started right up. Ever since it has started up well other then every once in a blue moon
jd b puller
03-28-2008 17:43:43
Do you have another tractor and a belt?
