JD 450
William Bergman
03-28-2008 15:46:31
My 450 (with a backhoe attachment) was running nice and then one morning i fired it up and got one big puff of white smoke and the after a few seconds it died and will not sputter even when I turn over the starter. A friend suggested that I squirt a bit of starter fluid in to determine if I have a problem with the fuel line or fuel pump. Any advice? I'm a city boy with a new toy.
Roy Suomi
03-28-2008 20:42:06
 Re: JD 450 in reply to William Bergmann, 03-28-2008 15:46:31
First step is fuel filters..Change them and prime them with the primer lever on the side of the transfer pump..There is a bleeder at the filter housing , pump primer till fuel comes out the bleeder..If there's a problem getting it to prime , check the fuel flow at the fuel shut-off at the front bottom of the fuel tank..If you take the line loose at the shut-off valve, there should be a steady stream of fuel there when you open the valve..If not , blow compressed air into the tank at the shut-off valve..Loosen the cap slightly but not enough to get a bath..If that doesn't help, let us know..There are several other places to look...always look for the easy stuff first..
William Bergmann
03-29-2008 09:33:04
 Re: JD 450 in reply to Roy Suomi, 03-28-2008 20:42:06
Thank you very much for the tips. These message boards are so cool. I'll let you know what happens. If you ever need an answer relating to graphic arts, just ask.
