Fuel Cap for 80/820/830
The Pennsylvani
03-28-2008 15:33:30
Was the original diesel fuel cap for an 80 the same as the ones for an 820 or 830 (two cylinder)? If someone has an original cap could you please post a picture of it? I know the replacement one directly from John Deere has the Buy Clean Fuel...lettering on it. Thanks.
WeirdDeere
03-28-2008 20:53:24
 Re: Fuel Cap for 80/820/830 in reply to The Pennsylvanian, 03-28-2008 15:33:30
Sorry, I've had a messed up week.
Here's a pic of the top
third party image
A pic of the bottom:
third party image
It works fine on my tank. And yes FIT, it's a vented tank. Sorry for the blurry pics, it's dark!
Brandon
F-I-T
03-29-2008 16:14:21
 Re: Fuel Cap for 80/820/830 in reply to WeirdDeere, 03-28-2008 20:53:24
And that's a vented cap. Sure it's original? Might be how it got all that extra moisture intrusion in there over time.
F-I-T
03-29-2008 16:12:39
And that's a vented cap. Sure it's otriginal?Might be why it got all that extra moisture intrusion in there over time.
WeirdDeere
03-29-2008 18:15:53
 Re: Fuel Cap for 80/820/830 in reply to F-I-T, 03-29-2008 16:12:39
I'm not sure if it's original, but that's what it's got. The Pennsylvanian had emailed me for pics. I never even considered if it was original or not. I never considered the vented issue either. I guess I should look to see if I can find the vent hole.
And you're right that might explain the rust. It's only rusty right around the neck and cap. Everything else is clean. I had it off a few years ago.
Brandon
F-I-T
03-29-2008 18:36:32
 Re: Fuel Cap for 80/820/830 in reply to WeirdDeere, 03-29-2008 18:15:53
The vent holes for those caps are at the each end of the raised bumps. The air goes into that center section, passes under the gasket area to a hole on the other side. so that it can exit down and around the outside surface of the neck. I can't speak to the vent on the tank, though the parts book show it, but if you have more than one point of ingress and egress, water vapor will find it. If you have only one point, the tank will expell moisture laden air during warm times, so that you only have the small amount of air in the top of the tank that can hold humidity. If air can pass freely, it can load and deposit moisture continuosly, during warm or cold times. It always helps to keep the tank as full as possible to help limit the amount of air in the tank, as the fuel will drop water to the sediment bowl, but air will hold water like a sponge.
third party image
WeirdDeere
03-29-2008 21:14:33
 Re: Fuel Cap for 80/820/830 in reply to F-I-T, 03-29-2008 18:36:32
Water in the air? Humidity? Wha?
You act like you grew up in Ohio or something.
Thanks for pointing out the vents, I'll see if I can find them tomorrow.
And yes the vent is exactly the same as shown in the parts book. I'm fairly sure I verified that it was clear, but my memory fails me.
Brandon
F-I-T
03-29-2008 21:59:57
 Re: Fuel Cap for 80/820/830 in reply to WeirdDeere, 03-29-2008 21:14:33
Well, I'm in Florida now, and Ohio ain't got nuthin' on northern Florida for average humidity.
WeirdDeere
03-29-2008 23:07:41
 Re: Fuel Cap for 80/820/830 in reply to F-I-T, 03-29-2008 21:59:57
I know, just joshing
Mike M
03-29-2008 08:15:20
YUCK ! That's got alot of rust on it .
MrJDMan
03-28-2008 15:57:24
the correct fuel cap is the same as the originals on an 820 or 830, but the replacements are different. many tractor were switched for the correct type to the new generation type. The key is to find the one with the lettering on it "buy clean fuel, keep it clean"
got to deerelydeparted.com for acurate pictures
F-I-T
03-28-2008 18:21:50
 Re: Fuel Cap for 80/820/830 in reply to MrJDMan, 03-28-2008 15:57:24
Are you guys sure about that? Wasn't the "Buy Clean Fuel --- Keep It Clean" cap the vented type, used on the lettered series that had no separate tank vent, but the plain cap, no printing cap used on the 70/720/730 for example, was the non-vented type. The numbered series on up had a separate vent tube. I think you need the smooth cap.
FWIW
Frank
The Pennsylvanian
03-29-2008 04:30:16
 Re: Fuel Cap for 80/820/830 in reply to F-I-T, 03-28-2008 18:21:50
Frank, this is kinda mindboggling as to what is "original". Parts book listed original cap as AR369R for the 80/820/830. Type in that number and you get AH83351 (replaces AR369R). When you order fuel cap AH83351, it comes as "Buy clean fuel...keep it clean". Now on Deerely Departed website for fuel caps, they don't list any caps for the 80, but two caps show up subbing for AH83351. One has the lettering on it, DDFC1029, and the other is plain, DDFC1048, which is listed for unstyled tractors. Is it possible this plain one is what I want??? Thanks.
The Pennsylvanian
03-28-2008 16:37:31
Not sure if I am following you yet - did the original cap on these say... Buy clean fuel, keep it clean?, as this is what you get now from John Deere with a replacement part number assigned to it. Deerly Departed doesn't offer a cap for the 80 and my cap is flatter with no lettering and won't lock when you turn it.
