1530 diesel in oil
Sean Griggs
03-27-2008 11:50:00
I have a 1530 that seems to be filling the crankcase with diesel fuel. It takes a few weeks to do this. I was tracing the fuel lines and it seems that there might be only a few places that this could happen. Does the Lift pump have a gasket behind it to the block? I dont think it could be an open injector as the engine runs great. Perhaps leakdown of cylinders but seems to have plenty of tourque and to me that would entail loss of compression. any ideas??
backwoodsfarm
03-28-2008 15:37:02
 Re: 1530 diesel in oil in reply to Sean Griggs, 03-27-2008 11:50:00
Sean- My 1530 did the same thing and it was the fuel transfer (lift) pump on the right side of the tractor. Don"t bother to rebuild it, just take it off, go to the dealer and get a new one. Put the new one on, change the oil and you should be good to go.
SRW
03-27-2008 14:27:36
Yes, the supply pump has the flap on it so you manually prime the fuel system. Its just like the manual fuel pump on older cars and trucks except for the flap and sometimes the rubber disphram will tear letting diesel through to the oil pan.
srw
03-27-2008 12:01:06
It could be the diaphram in the supply pump or the seals on the injection pump shaft. Take the supply pump off and hook the lines up. Then with the fuel on work the pump and check for leaks at the point where it mates to the block. If the injection pump is leaking be sure to check the brass bushing that the seal runs on. If it is grooved it will just leak again. Hope this helps
Sean Griggs
03-27-2008 12:15:11
 Re: 1530 diesel in oil in reply to srw, 03-27-2008 12:01:06
is the supply pump the pump with the flap on it? the one i was calling the Lift pump? sorry i had a ford 5000 before hehe. I am actually trying to do this for a lady who owns it at a horse farm. I have no manual to work with.
