420 -W tractor
Mtc
03-26-2008 17:11:50
Hi guys looking at a 1957 John Deere 420-W to buy with a 5 speed and 3 pt.Any thing I should be looking for on these tractors that will cost alot to repair?Any advice would be appreciated.Mike
Dave H
03-27-2008 05:59:35
 Re: 420 -W tractor in reply to Mtc, 03-26-2008 17:11:50
Roger
Note I meant a pittawnce of the quoted 800 buck price. I had one made by a guy in MO two or three years back for 125.
Last time I talked to Dave Cook he said that he had a guy in his shop that was rebuilding them. I assume he is still there and does 715-373-2092
I got in contact with the guy that did mine thru Dave's neighbor (John Shepard) who specializes in Dubuque's also. 715-265-4988 I have lost contact with the guy in MO, but if my rusty brin recals his last name may have been Coy.
If you strike out give me an email and I will see if I can still establish contact with the guy in MO [email protected]
Good Luck
Roger in Michigan
03-27-2008 17:45:28
 Re: 420 -W tractor in reply to Dave H, 03-27-2008 05:59:35
Thanks, Dave. I'll follow up on this.
Roger
jockey
03-26-2008 19:40:13
So whats a good clean 420 w worth with slant steer. good straight metal. all around a real good clean tractor stuck worth. I believe its wear in its life is minimal. thanks
Dave H
03-26-2008 19:02:05
Mike
In my humble opinion, that is a center of the road 420 W. That 5 speed had to be an optin, and I really like the extra gear in mine. The three point was standard on that model (I think) unless ordered without it.
the expenside U Joint in the steering did not come until the 58 model and if you go that route there are a couple of suppliers that are rebuilding that joint for a pitance of the price on the one from JD.
Yep that is a good one except your steering wheel is not slanted like the 58 lol.
Roger in Michigan
03-27-2008 03:13:46
 Re: 420 -W tractor in reply to Dave H, 03-26-2008 19:02:05
Dave, where can you get the steering u joint for a "pittance" as you said? I could use one or two. I did not know anyone was making them aftermarket.
Thanks!
Roger
rusty wheel
03-26-2008 17:58:59
Does your 420 have a slanted steering wheel? If it does the u joint in the steering shaft is $895.00 at the John Deere Dealer in London Ohio and John Deere had one in stock. As far as I know, they still have it..... ....rw
James22
03-26-2008 19:19:44
 Re: 420 -W tractor in reply to rusty wheel, 03-26-2008 17:58:59
That is almost unbelievable! I wanted a new one for my 430W about 10 years ago and JD was asking $95 which I thought was outrageous. Found a NOS for $25 at an old "Mom & Pop" JD dealer somewhere in Georgia. I suspect that dealer is closed.
