Draft Control
Gbusse
03-26-2008 15:23:40
I have a 1010 JD, when pulling implement, sometimes goes deep in the ground, or lifts completely out. I have set the draft control to the least sensitive setting but lift continues to jump around and to an extreme. Any suggestions?
Howard Weeks
03-26-2008 17:00:13
 Re: Draft Control in reply to Gbusse, 03-26-2008 15:23:40
That hyd system is very near the same as what I have on a 430. If there is any type of leak down of the hyd pressure, the implement will drop at a rate depending on how bad the leak is. Eventually, the system will detect that the system has dropped and it will correct the drop by raising it back up. Big leak down = fast cycling, etc. I had totally rebuilt mine and had the cycling problem. It is a dual system and there is a valve on the left side which can be used to parallel the cylinders for lifting. It wasn't tight and caused my problem. The draft setting will have little control of this problem.
johns48jdb
03-26-2008 15:55:40
you may need front end weights to help hold the front end down. if its aways riding up it will cause the implement to go deeper and then when it goes back down the implement will ride up. its a never ending battle. get the manual as suggested
Bob
03-26-2008 15:50:53
There's LOTS of adjustments inside that rockshaft mechanism. You need a genuine Deere shop manual at hand if you are going to attempt to make adjustments.
Also, does the lift "hold" in the "up" position, meaning the lift cylinder pakings ar OK?
Zane Giles
03-27-2008 08:42:59
 Re: Draft Control in reply to Bob, 03-26-2008 15:50:53
I have a 1010 w/ duals that has similiar problems but per your question. My Hydraulics drop(leak off) rapidly when I shut her down. My question is where are these seals that are bad so I can replace them?
