D' belt pulley removal
Tim Pyke
03-26-2008 11:25:50
Needing help on removing the belt pulley. We have removed from the Cover to the pulley bearing, the pulley still is not coming off. Used PB Blaster to see if it could free anything up. We have soaked it, smacked it , soaked it again & again, hit it etc..... Still not coming off. Crank is also siezed, we think the culprit is in the clutch area. We removed the pistons and block as well..(had to pistons were seized.)
The book talks about the Fork shaft and bearing being removed for the pulley to be removed but I am not seeing how it would hold on the pulley itself...Thoughts?
Tim Pyke
05-27-2008 08:22:21
 Re: D' belt pulley removal in reply to Tim Pyke, 03-26-2008 11:25:50
Finally! - We got it off ! went to Lowes and bought 3 lengths of chain 18", 3 finger jaw puller bracket (no fingers), and a inoperable bottle jack [mounted horizontally]for a spacer. The chains were 3/8 Heavy Duty. I used my breaker bar and turned the screw for the jaw puller and it popped about 15 times before coming off.
Tim Pyke
04-01-2008 08:29:15
Thank you for the information. We got the clutch fork assembly off and it is still on there... it is rusted pretty good inside. We have been hitting the area in and out with PB Blaster waiting for it to break the rust down and come loose.
bigtim
03-27-2008 15:56:46
had mine apart last weekend you must remove clutch linkage rod pin and then remove the 4 bolts that hold the fork in then pull fork out carefull not to tear the gasket then pulley will pull right off carefull not to tear up the seal it rides in good luck
d. coleman
03-26-2008 17:48:13
the clutch is actavted by this fork which is connected to the clutch in the same way a clutch fork operates a inline engine/trans. setup. on my 51 "B" the fork is removed by removing 4 bolts on the front side of trans. housing inboard of belt pulley. follow your clutch lever lenkage to the shaft going into the trans. housing. this should be the block which has to be removed. good luck, d. coleman ps. belt pulley is the housing for the clutch.
