4520 hydraulic leak
Chris Sherron
03-26-2008 09:45:50
My 4520 is leaking hydraulic fluid around the clutch area and around the bottom left draft arm pivot shaft.Seems to leak more hyd. fluid when the PTO is engaged. Any suggestions on where to start?
matthies
03-27-2008 09:02:13
 Re: 4520 hydraulic leak in reply to Chris Sherron, 03-26-2008 09:45:50
With the tractor and pto running crawl under the tractor and remove the clutch inspection cover and look at the pto pistons and housing. If the housing is pulsating in and out your pto valve will have to be adjusted or you'll be doing the split job again. Other wise just make sure the operating rod that goes into the top of the valve is bottomed out when your engagement lever is pushed ahead. Hope this makes sense to you. chris
K.B.-826
03-26-2008 22:32:40
The leak around the lower end of the hitch arm is probably a load control shaft seal. Not too bad of a job to fix, just need a new load shaft, seals and bushings, and a couple hours of labor. The clutch housing leak is probably coming from the o-rings on the pistons that push against the PTO clutch operating bearing to engage the PTO clutch. Somewhat common problem on a side-console tractor. Requires a clutch housing split to fix, probably a new clutch while you're in there. $1000-$2500 if you go all out and put in a clutch, rear crank seal ect. while you're in there, depending on who does the labor.
Zane Giles
04-03-2008 11:55:56
 Re: 4520 hydraulic leak in reply to K.B.-826, 03-26-2008 22:32:40
I just fixed a control arm seal on my neighbors JD. He put 20 gal of fluid through that thing doing fence all summer and I got it fixed in 20 minutes and a $10.00 part!!!It"s real easy. Get the improved seal(mine was purple) cost around $10.00 ea. I went ahead and did both sides at that price.
