JD 4230 Hi-Crop Powershift
TD
03-25-2008 18:42:20
Are they considered rare? Anyone know how many made?
1020HC
03-26-2008 16:58:56
 Re: JD 4230 Hi-Crop Powershift in reply to TD, 03-25-2008 18:42:20
J.R.
Is it also possible to count the number of 4240,4440,4050,4250 and 4255 hi crops?
Maybe its already been done with some as I've heard a few numbers but could just be rumor??(Probably ranking right up there with sasquatch.) I'd help count if looking for volunteers. : )
I've noticed on the rollgard structures on the newer ones in the yard here that the tags also state they are approved only for hi crop models-is this how they are distinguished in the archives?
Thanks J. R.
(email is also open)
danb4230hc
03-26-2008 16:08:25
I talked with a retired JD engineer who worked on the 4230 and 4430 series high crops. He couldn"t give any specific number of 4230 high crops, but said he remembers being told to keep the "special" parts required to a minimum for an expected production of less than 400 units. He said he thought possibly the number ended up at around 384.
J.R. Hobbs
03-25-2008 21:03:36
The way the records were kept on the 4230's, it is impossible to tell how many were made for the first two years of production. After that, the records changed, and the numbers could be counted, but very likely it will never be done. Still, compared to the total number of 4230's made, the Hi-Crops would have to be a very small percentage of the total, and very probably worth restoring now, while parts are still in decent supply. Ten years from now,parts availability might be a different story. If you can afford to salt it away, it should be good property at some time in the future. The rare 4230 Hi-Crop would be one with a Creeper transmission.
JDHICROP
04-22-2008 19:13:54
 Re: JD 4230 Hi-Crop Powershift in reply to J.R. Hobbs, 03-25-2008 21:03:36
JR - I have been researching historically the 40, 50 and 55 series JD Hi Crop SG, RG and unit s/n"s for a number of years. I agree that production numbers are not commonly available. S/N records for the later series are definitely better but one can get a pretty good idea by tracking both the RG or SG and the unit s/n"s and seeing how they lay out relative to the total series s/n spreads. The RG s/n for 40 series (as no SG's were offered then) and RG and SG s/n"s for 50 and 55 series are unique for Hi Crop option but the unit s/n's are consecutive with RC's. However JD shipping records etc can pretty definitively narrow the probability of a valid factory Hi Crop unit s/n to a high level. What I have found is that knowing about where the Hi Crop s/n in question fits into the known earliest and latest series production sequence s/n"s one can easily prove if the RG or SG has been changed, added or otherwise altered. Once you get familiar with the unique part number sequences and s/n"s of these monsters you can spot a non numbers matching unit fairly easily. I own a 1980 4440, 1983 4050 and 1990 4255 JD all RG PS 466 engined Hi Crops and have hundreds of digital images of every tractor I have verified thru research etc. This helps one restore these units to their factory original configurations. The 4050 RG/SG equipped Hi Crops are the extremely rare birds as production was cancelled by JD early on, with 4255"s next and last 4440"s. I feel many more 4240 Hi Crops are in existence than the 4440 which was I believe the highest powered Hi Crop JD ever produced. Note that the RG and SG"s for Hi Crop"s are a completely different assy P/N than for RC"s as they are more heavily reinforced to protect the operator. Interestingly the 55 series RG"s and SG"s do not begin sequentially with the 1st 55 series Hi Crop but follow the 50 series leading to interesting conclusions/questions wrt production numbers. These Hi Crops are real heavy units and have been loads of fun to restore particularly the much more complex electrical system on a 4255. If anyone has such a unit I would be happy to include it in my excel spreadsheet s/n records and assist you in your search and restorations as I am able. DPM
