pipe to oil pressure gauge
Jon Hurley
03-25-2008 17:49:15
I have a '41 B. there is a fitting on the governor and a rubber hose that goes to the oil pressure gauge. according to the parts book it should be a "pipe". what diameter of metal pipe should I be looking for? it appears from the parts book that it has a bushing and nut similar to compression fittings like for plumbing, but obviously smaller. is this correct?
Indiana Boy
03-25-2008 19:55:11
 Re: pipe to oil pressure gauge in reply to Jon Hurley, 03-25-2008 17:49:15
I use steel brake line and brass farrels. Just get a piece a little longer than you need so that you can cut the flares off both ends. Original lines seemed to be more like steel lines than copper.
jd b puller
03-25-2008 18:44:22
 Re: pipe to oil pressure gauge in reply to Mike M, 03-25-2008 17:49:15
Jon, you can still get the part B1941R from Deere. The Downside is that it's almost 43 BUCKS!!!!
Tube measures 3/16" OD, not sure where you would get the little sleeves that go in the ends if you make your own. Good luck.
There needs to be an elbow where it goes into the gauge and where it comes out of the gov housing as well.
Jon Hurley
03-25-2008 18:25:02
cool Rob, thanks.
RobMD
03-25-2008 18:10:56
Yes. If I recall, it was 1/8 inch copper tubing. You use ferrules and the appropriate fittings. Elbow out of the governor, straight up to the gauge where you'll have to make some intricate but not too hard bends. Don't kink the piping.
