Identification of John Deere Carb
ncpapaul
03-25-2008 15:20:48
I bought another JD 60 parts tractor and this one had a carb with it that I cannot identify. It is dual throat, marked A5380R. Can anyone clue me in? Also along with the loose parts came another dual throat Marvel Schebler and the only marking I see yet are on the flange: 10-B-5 THanks for any help, Paul
1958johndeere620
03-26-2008 14:48:09
 Re: Identification of John Deere Carb in reply to ncpapaul, 03-25-2008 15:20:48
On my 620 the tag was covered by paint. I had never messed with a JD carb before so I did no know where to look. Scraped off a round part with a rivet looking center and there it was.
Duane Larson
03-26-2008 06:45:29
Paul,
Normally Marvel Schebler two barrel carburetors have a round disk located on the flange which attaches to the manifold. On that disk is the MS part number, like DLTX 85, and perhaps other info is stamped in, like the date. If you are missing the disk, the load nozzles and the idle hole drill sizes can be used to identify the carb. Your A5380R is not a carburetor part number I am familiar with - it doesn't show up in any carburetor book I have, nor in the Deere Master Parts Index.
The only thing I can come up with is it may be a DLTX109U - the universal carburetor provided sometime around 1969. It had an aluminum tag riveted to the body, and they do come off.
ncpapaul
03-26-2008 12:33:10
 Re: Identification of John Deere Carb in reply to Duane Larson, 03-26-2008 06:45:29
Thank you Duane, the A5380R has been quite a puzzle to my two cylinder friends here. It sure looks like a JD carb and number cast into the body, very much like most of the cast in JD part numbers all over my tractors. The two 60s where these came from were on a cotton farm and one had a picker mounted on it. I will keep looking, and thanks to anyone else who helps, Paul
