GP FANSHAFT BEARING
SCOTT MCKELVEY
03-25-2008 12:55:37
I am in need of the front fanshaft bearing for a 1929 GP. Does anyone know a part number, either Deere or aftermarket (NAPA, Timken, etc.)
Thank you
Chooch
03-27-2008 08:00:22
 Re: GP FANSHAFT BEARING in reply to SCOTT MCKELVEY, 03-25-2008 12:55:37
Scott,
The Timpken part numbers are similar to Napa:
Timpken 09194
Timpken 09074
Chooch
jdal
03-25-2008 18:08:16
JD7358R crosses to NAPA BR09074 the cup JD7250R crosses to BR09194. I just replaced them in the 29 GP. One set each end of fan shaft and one in the governor left side.
Mark-IA
03-25-2008 14:08:15
JD7358R
PBrowning
03-25-2008 15:04:52
 Re: GP FANSHAFT BEARING in reply to Mark-IA, 03-25-2008 14:08:15
Still available through Deere for roughly $25! Thanks Mark. (PatB)
PBrowning
03-25-2008 13:43:25
Do you have the old parts? Can you get a part number or two from those pieces? How about the name of the manufacturer? Something to go on would be the next logical step.
You tossed out the name Timken -- is that a tapered roller bearing? If yes, raw measurements taken to any bearing house will get you home. I'd be a bit surprised if it were Timken, but then what I know about a GP would fit into the eye of a needle.(Pat)
