3130 Slow Gutless Hydraulics
Big D in MB
03-25-2008 12:44:56
I'll try to give as many details as possible...
We've always had hydraulic issues with this particular tractor. My father, never liked it so it's been sitting for 5 years or so in a shed. This last fall I pulled it out, changed the fluids, and did a little fixing here and there, nothing major.
The hydraulics worked fine in the warmer weather of the fall. but this winter strange things have started happening.
1) the trans/hydraulic oil is merky, and a light grey color. even after changing it, like it has water in the fuild, or possibly air bubbles from a high pressure internal leak.
2) the brakes will apply themselves sometimes, making the pedals completely stiff to press
3) the hydraulics are slow. really slow. It was intermittent but now it's permanently slow.
4) I loose power steering (due to the loss of hydraulic power I'm sure)
5) the PTO seems to effect the hydraulic power. I'm not sure exactly why but when using the PTO you will eventually loose your steering.
I do plan on changing the trans/hydraulic fluid again, but at the same time I'm like to have a look into these issues. Does anyone care to cast a guess at what might be causing these problems? I do rather enjoy this tractor, it starts pretty decent and has more than enough power for feeding my cattle and the locking diff has proven itself to be more than a little handy in this sloppy spring thaw weather.
Big D in MB
Big D in MB
03-26-2008 10:08:14
 Re: 3130 Slow Gutless Hydraulics in reply to Big D in MB, 03-25-2008 12:44:56
I see. It is possible that the incorrect fluid was in the transmission before. Now, I'm guessing I should be looking at all these brakes and wet clutches. I'm thinking that if the oil before was incompatible, it could be breaking down the faces still?
The tractor was good and warm when I changed the fluid. Meaning, I was working the whole machine moving around soil. I'll change the fluid again soon and see what I've got for sediments in the case.
buickanddeere
03-26-2008 09:07:30
If some tinkerer has dumped in GL-5 gear lube. or some bargain trans/hydraulic oil that does not say" wet clutch compatable". Odds are the fiber friction material on the brakes, pto and high-low shift is flaking off and plugging everything. Metal to metal contact is next $$$.
Tx Jim
03-26-2008 04:30:25
 Re: 3130 Slow Gutless Hydraulics in reply to farmboy169, 03-25-2008 12:44:56
Big D I'm not familar with a 3130 but I think it's very similiar to a 2840/2940 as far as hyd's go. The pto and hyd hi-lo can lead to hyd slowness from leaking tubes under gear shifter that supply oil to these functions,also rockshaft valves can leak. As previosly suggested check sump screen fo debris. I would also think a JD tech manual is required.
JOHN DEERE GUY
03-25-2008 18:51:32
Their are a ton of that series tractor in our area (Ontario Canada). I have a 2130 that has had similar symptoms. On mine the paper like brake material came off the disk and clogged up the inlet screen in the transmission. I ended up doing brakes on both sides and changing many hyd filters.
buickanddeere
03-25-2008 16:51:27
Did change the filter, screen and flush the hydraulic system while it was warmed up?
