50 power block
Jake Winn
03-25-2008 11:55:27
I talked to a guy who has a 50 for sale and he says it has a power block in it. I have never seen one before and am curious how you tell that it has one. What is the difference between it a standard block and pistons.
Thanks
jd b puller
03-26-2008 07:11:08
 Re: 50 power block in reply to msb, 03-25-2008 11:55:27
Jake, as Mike indicated, it will say "Power Block" on the top of the casting between the water manifold and the crankcase. It should also say 5-3 right under it. It will have 5" aluminum pistons in, no petcocks (don't know if the 50 originally did or not) and will be slightly higher compression than stock. Tractor pullers like them because it is quick HP. Can easily be bored to 5.125"
Resting Relics 1
03-26-2008 05:57:14
 Re: 50 power block in reply to Jake Winn, 03-25-2008 11:55:27
Jake, Some think the blocks were originally made by the MxW Machine Co. as they were known in those days. That's up for discussion. They were available for lots of models, A,B,G,50,60,70, that I know of. They were sold by the Tractor Supply Co. Want to know more check out the archive section of this forum. Very Helpful. John
Mike M
03-25-2008 12:06:35
If you look at the block it says power block right on them. They were made with increased bore sizes larger than you could get from just oversizing a std. block.
