2240 Pump standby pressure?
foxprints
03-25-2008 09:18:40
Can anyone confirm that the no load standby pressure for a 2240 hydraulic pump should be 2750PSI? I am rebuilding one & replacing the stroke control valve so it will need to be adjusted at startup.
ccjersey
04-01-2008 20:11:11
 Re: 2240 Pump standby pressure? in reply to foxprints, 03-25-2008 09:18:40
I would err on the low side. Had a 2440 that cracked the rockshaft housing when the pump pressure got too high. Turns out the rockshaft cylinder stroke is limited by the rockshaft housing, so too much pressure = trouble.
powertech84
03-26-2008 15:27:50
 tx jim in reply to foxprints, 03-25-2008 09:18:40
i meant you'd probly run out of threads on the adjustment screw, if you get one of those out or in to far the oring doesn't seal. structuraly it would probly hold for a while.
Resting Relics 1
03-26-2008 06:02:31
Back during my wrench twisting days working for the local John Deere dealer I did a lot of work on the Iron Horse 40 series tractors. The pumps were set at and the hydraulic system was built to operate at 2250 psi. John
foxprints
03-26-2008 05:47:42
This site has the pump for the 2240 listed for sale & the description states that the no-flow standby pressure is 2750PSI.
Tx Jim
03-26-2008 04:48:36
 Re: 2240 Pump standby pressure? in reply to Mike M, 03-25-2008 09:18:40
powertech84 may I ask why you think that the hyd pump won't attain 2750 psi? I know that back when 4430's were new I had one that we installed a kit for raising a heavy 7 row bedder that raised stand-by pressure just long enough to raise load. Long story/short valve in kit malfunctioned and blew rochshaft piston housing wide open. I asked JD service dept in Dallas what maximum psi was and they replied limited only by size of engine pulling pump. Granted the pump on a 2240 isn't as large as a 4430 but I think 2240 pump can reach 2750 psi but 2250/2300 is adequate.
powertech84
03-25-2008 16:13:57
spec is 2200-2300. i don"t think you could get 2750 out of that pump if you wanted to
Mike M
03-25-2008 09:45:51
I kinda thought stand-by was set at 2250 ?
