JD 40 Welch Plug in Head
Bob in IN
03-25-2008 09:17:19
There is a welch plug in the head of my JD 40. The JD Service Manual only says to be sure it is installed before installing head - no other instructions. Why is it here? There is a hole in the middle so it does not seal anything??? The picture in the manual also shows a hole. Mine is somewhat corroded but the hole appears to be as large as the one in the picture. Do I need to replace it?
J Chantry
03-25-2008 18:51:04
 Re: JD 40 Welch Plug in Head in reply to Bob in IN, 03-25-2008 09:17:19
Over the winter I rebuilt my 40T engine. The welch plug was very corroded. I replaced it, part # M460T, still available from JD for $8.22. If I were you I would replace it. As for what it does, I don't know, but my guess is it restricts the coolant flow on that side of the block to even the cooling on each side?
J Chantry
03-25-2008 18:50:57
Alan Williamson
03-25-2008 10:29:10
IF YOU CAN STILL GET ONE FROM DEERE, IT MAY NOT BE A BAD IDEA.
Alan Williamson
03-25-2008 10:29:03
