Fertilizer Plates
Christos
03-25-2008 08:20:33
I gotta question for you all. Do you all know where I could get at a reasonable price the plates that go in the fertilizer bin on a FB Grain Drill (PN T317M)?
Mine are still intact but rusted/corroded in places. I thought about making my own (make a mold and cast) but I don't know how to do that.
Christos
James22
03-25-2008 09:21:15
 Re: Fertilizer Plates in reply to Christos, 03-25-2008 08:20:33
I assume you are talking about the "finger" star wheels. If not ignore the following, because making a drop hole casting would be difficult. Couldn't you use plate steel and make the star wheels? It would be possible make (carve) one out of wood and use it with a sand mold, but alot of work for an old drill unless it was unusual, such as a family heirloom. If you go this route be sure to make the model about 10% larger because the metal will shrink when it cools. Remember that you will need to add a couple of risers along with the filler hole to be sure that air escapes and thereby not have casting voids. I would probably overkill in this area and have a riser on each "finger" of the wheel. For the sand casting supplies go to a company that handles refractory supplies. In the end you will probably have more in the casting supplies than if you bought the parts from JD. However you would be trained and prepared for the next casting project.
Christos
03-25-2008 13:37:23
 Re: Fertilizer Plates in reply to James22, 03-25-2008 09:21:15
I was talking about the plates that go in the bottom of the fertilizer bin that the agitator wheels fit into.
parts depot has some NOS ones three years ago but I couldn"t afford them at the time and they didn"t have the quantity (only had 5) that I needed (11)
would something out of one of the later drills work?
Christos
James22
03-25-2008 14:28:07
 Re: Fertilizer Plates in reply to Christos, 03-25-2008 13:37:23
I really can't answer your question, but would probably buy one new one and see if a local machine shop could duplicate it for a reasonable price, at least less than you can buy them from obsolete parts depot. Where to go for a good machine shop is a good question. Several years ago Pataskala had a machine shop but I believe it is gone. To my knowledge Kirkersville and Etna never had one, but don't know about Summit Station. Perhaps Johnstown or Newark?
Christos
03-25-2008 17:33:43
 Re: Fertilizer Plates in reply to James22, 03-25-2008 14:28:07
James, I"ll have to check that out...I"m going home this weekend so I"ll see if I can"t figure out where (and if its still there) in the ole stomping grounds it is. Thanks
Christos
