4320 smokes
Bill Lisbon
03-24-2008 18:09:13
Just finished overhauling a 4320. When you first start it up it smokes badly [ white smoke smells like unburned fuel] new rings, had injectors checked, had injection pump rebuilt, checked turbo, after it runs for about 10 min. it clears up ,but never stops smoking completely. Any ideas.
powertech84
03-25-2008 16:18:32
 Re: 4320 smokes in reply to Bill Lisbon, 03-24-2008 18:09:13
sounds to me like the cold start piston in the pump is sticking
Mike M
03-25-2008 06:46:42
My cousin had a pump problem with his 4020 got an exchange unit from somewhere ? Turned out they sent him one for a much bigger model tractor. I think he finally got it straightened out and got another pump. So it is possible the pump shop made a mistake.
LarrySTN
03-24-2008 21:46:51
You should recheck your pump timing. Retarded injection timing will also give the symptoms you describe.
twopop
03-24-2008 20:02:19
300 psi is not enough,should be 350 375. i would take the exhuast manifold off and start it up.find out if all 6 are smoking or just one.were the valves lapped in.all diesels should be but a lot of shops dont
Bill Lisbon
03-24-2008 19:52:08
I have around 300 lbs, compression pressure. Does this seem like enough? I am not getting any water in the oil and the smoke does not have a antifreze smell.
Wilamayb
03-24-2008 19:27:54
White smoke is caused by combustion temperatures that are too low. This can be caused by water in the combustion chamber or low compression.
A couple questions to help narrow the problem... Did you have the valves ground? Where did you get your head gasket? Did you install new rings only, or a whole kit? Did you replace liner orings? Did the parts come from Deere? Are you seeing oil in the water or water in the oil? Are you seeing lots of bubbles in your radiator?
There are a couple things that come to mind. Either compression is low from combined things such as ground valves that a recessed in the head, a head gasket that is too thick, and possible wrong pistons. This is all assuming that you did not use a Deere kit. If this is the case after the engine warms the compression becomes great enough to fully combust the fuel. The other option is water in combustion which would also be burned out in a period of time after start-up.
Fuel can cause your problem if the injectors a dumping. Do you respect the shop that did your work? You may want to take those injectors back to have them checked for pattern and opening pressure again. Of course this check would be the easiest to accomplish. Always start with the easiest.
msb
03-24-2008 19:18:45
Did you used a genuine John Deere overhaul kit? Have the head rough surface ground ? Use new head bolts? Use the latest head torque proceedure?
Bill Lisbon
03-24-2008 19:23:47
 Re: 4320 smokes in reply to msb, 03-24-2008 19:18:45
I just put new rings and rod bearing. I had the head resurfaced and installed all new valves. I used the old head bolts, they looked good, and I torqued the head, using the John Deere manuel as a guide.
