4250 15 speed powershift slipping
Miles
03-24-2008 11:23:20
I have a 4250 thats slips under load in all gears except 6 and 15. Any suggestions on where to look? Step-by-step instructions to diagnose problem? External filters have been replaced.
You can shift thru all gears as normal but if you apply load, tractor stops in all but in gears 6 and 15
Thanks in advance
mattd
03-24-2008 17:39:22
 Re: 4250 15 speed powershift slipping in reply to Miles, 03-24-2008 11:23:20
behind left battery is the clutch valve housing. there is a port labeled sys press. see what the pressure is. should be greater than 180psi at 2000 rpm. behind this on corner of transmission is another smaller housing with some big lines going to it. there is another port on the side of it. this is transmission lube should be greater than 21psi at 2000 rpm. report back with pressures. 6 and 15 dont have much in common so its odd they are the only ones working. on the right side of the trans is the shift valve housing. take the pressures at each of the ports. c1, c2, bhi, clo, b1, b2, b3, b4 and c3 port is on the accumulator line. small can up and to the left of the shift valve housing is where you will find this. left side of transmission is a lever, i cant remember which way you move it but move it to the position it isnt in. this dissengages the differential from the transmission. now with clutch up shift through all gears check pressures at sys press, lube, and shift valve housing. record them and look for a pattern.
mattd
03-24-2008 17:52:28
 Re: 4250 15 speed powershift slipping in reply to mattd, 03-24-2008 17:39:22
another thought. cut your filters open and look for for metal, burnt clutch material, etc. take the sump screen out and check it too. is your oil dark in color? if it is dark either your rear main is out or its burnt clutches darkening the oil
Miles
03-26-2008 19:54:03
 Re: 4250 15 speed powershift slipping in reply to mattd, 03-24-2008 17:52:28
mattd...
I should have checked the tractor closer before posting. All odd forward gears and all reverse gears work fine. Only even numbered forward speeds slip under load.
Oil is clean, no debris or color change
I have not done any flow or pressure tests yet.
Miles
44 Diesel Tech
03-29-2008 21:33:22
 Re: 4250 15 speed powershift slipping in reply to Miles, 03-26-2008 19:54:03
Planetary failed between C1/C2 and main trans. I think it's called C hi and B lo. Split tractor between engine and trans. I have done many of these repairs. There is an update on the parts. (not warrany) (drive disk is thicker) Needs other parts to go with it.
Howard
