Implements
schlichtemeier
03-23-2008 18:17:32
Looking for an 8' blade for my 2640. As close as I can get with my lower arms is 28". I believe to use a Cat 1/2 blade, I need to be 26". Given I will only be using the blade for snow and light dirt work, I am not sure I need a Cat 2 blade and the price is significantly different bewteen the two. I see there is a block bolted on each side of the PTO, which prevents the arms from coming in any further. Can I take them off?
thanks, Chad
Dave Sherburne NY
03-24-2008 15:09:25
 Re: Implements in reply to schlichtemeier, 03-23-2008 18:17:32
With the weight and power of a 2640, you would be
a lot better off with a cat 2 or 3 blade. Go to an
auction and buy a real heavy blade that the tractor
won't destroy. If you go with a cat 1, I wouldn't
ever turn it around and push backward with it well
yea I probably would, but you better be real careful or it will fold up on you.
jhill52
03-24-2008 08:02:16
I think you can either turn them around flip them upside down to use Cat 1 equipmrnt. Owners manual would tell.
