3020 wiring help needed
Montana3020
03-23-2008 08:21:35
third party image
I have a 1964 3020 gasser. Since I bought it she"s ran poor at best and now she wont run at all. I don"t think the wiring was done right from who ever had it before me. While she was running I changed the old generator to a alternator added electronic distributor and a flame thrower coil. I took out the old wire harness which was in bad shape. I need to know how to wire the ignition switch to the starter to the coil, oil pressure light and alt/gen light ect... I have the diagrams from the JD web site and from the manual. I have the lights working ok and she will turn over but I am getting no spark at the plugs. I am a rookie when iy comes to electronics. I would appreciate any help.
teddy52food
03-24-2008 06:46:14
 Re: 3020 wiring help needed in reply to Montana3020, 03-23-2008 08:21:35
In the picture of the coil, is the wire from the starter on the dist side of the coil? It looks like it in the picture. Put that wire on the other side so the 12 volts from the starter solinoid goes through the coil then through the dist.
jturbo10
03-23-2008 12:34:01
I just converted my JD 3020 gasser to negative ground and single wire alternator. Once you do this you can get rid of the voltage regulator. The alternator was converted by an electrical shop for me. I ran the 10 guage wire from the alternator to the amp guage and then a wire from the amp guage to the starter power post. Ensure your electronic module is a negative ground module and the coil is made for electronic ignition. I used a Pertronix EI and an Acelerator coil. I also added a new saddle battery and all new heavy duty copper battery cables. After some carb adjustments and resetting of the timing it runs strong and starts immediately. I also regapped my plugs to about .45 to take advantage of the hotter coil. I also used a visible spark plug tester to insure I had good spark to each cylinder. Installed new 386 spark plugs but I"m told there are even better plugs...think they are 1186s but I"m not sure. Check other threads for recommendations.
Duane Adkins
03-25-2008 20:12:04
 Re: 3020 wiring help needed in reply to jturbo10, 03-23-2008 12:34:01
Hello Montana, did you get the 3020 running?
Duane Adkins
03-23-2008 08:42:51
Is the battery negative side wired to the frame? Put the positive side of the hot wire to the coil's positive post. Run the wire to the distributor from the negative post of the coil.
Montana3020
03-23-2008 08:56:53
 Re: 3020 wiring help needed in reply to Duane Adkins, 03-23-2008 08:42:51
third party image
Hi Duane,
I have converted the old generator to a alternator and changed the positive ground to a negative ground system. here is a picture of what I got.
