67 4020D block heater plumbing question
Jason(ma)
03-22-2008 05:39:51
In looking through the archives I see there is several different ways people are plumbing a block heater into the early style blocks on a 4020. My thoughts are to replace the line that goes from the bottom of the water pump to the oil cooler with a tank heater. What am I missing with this idea? Is this going to be backwards for themosyphoning to work? drawing from up high and replacing down low on the block.
mechanic fred
03-22-2008 07:39:43
 Re: 67 4020D block heater plumbing question in reply to Jason(ma), 03-22-2008 05:39:51
the best way to install a block heater of the tank type is to take the coolant out of the block drain and return it to the cylinder head at the rear of the engine if possible. Thirty two years in the arctic I think this works the best other than moving some place warm!!
Gerald J.
03-22-2008 08:57:31
 Re: 67 4020D block heater plumbing question in reply to mechanic fred, 03-22-2008 07:39:43
That's what the JD service manual shows.
Gerald J.
Mark-Mi
03-22-2008 13:55:07
 Re: 67 4020D block heater plumbing question in reply to Gerald J., 03-22-2008 08:57:31
I am installing a JD coolant heater kit on my 1968 4020 now.Can't get the threaded plug out of the head.Takes a 9/16 Allen wrench.I put a 1 1/2 foot pipe on the Allen wrench and couldn't break it loose.I am afraid if I pull too hard I will strip the plug.Can I take my torch and heat the head around the plug without damaging the head?
Is the back plug much better for distributing heat than one in middle just behind fuel filters.Less stuff in the way there,injection pump lines etc.
Hope this helps the original poster also.Thanks Mark
jdemaris
03-22-2008 17:27:07
 Re: 67 4020D block heater plumbing question in reply to Mark-Mi, 03-22-2008 13:55:07
There's not sense breaking something something. If it won' budge, tap into the thermostat housing instead - it will work just as well that way.
shoes
03-22-2008 16:33:00
Try heating the plug it self. Get it hot, then spray it with water. I know this sounds backwards, but it works. After this I bet it'll back out pretty easily. Never had it fail yet
Gerald J.
03-22-2008 16:16:59
My gas 4020 came with the block heater. So far I've not tried to start it colder than zero and didn't need heat then. Good choke and ignition helps with cold starting of the gas engine.
If I did have to remove one of those plugs, I'd apply moderate heat, Kroil, shock, and vibration. Probably figure a 3' pipe was more appropriate or a good 1/2" impact wrench (though if that didn't work, I might reach for a 3/4" air impact wrench).
I'd think one of the plugs near the middle of the engine would be best at heating more of the engine than a plug at the end.
The plugs have had 40 years immersed in water and were probably put in with paint on the threads and been painted over at least once. They weren't expected to come out easily.
Gerald J.
