50B starter
Paul in Ontario
03-21-2008 18:07:25
Have 6 volt positive ground original battery cables starter not rolling over well battery tests ok 6.28 volts and load tests ok
does start well half to full revolution with choke and starts have tested starter seems to spin well with no load will turn over well when battery charger connected in boost mode will start but draws large load on ac side of charger
anyone any guesses
Thanks Paul
John T
03-22-2008 06:19:06
 Re: 50B starter in reply to Paul in Ontario, 03-21-2008 18:07:25
Too sound like a broken record, Id use 00 gauge Battery n Starter n Ground cables on a 6 volt system and you might try to remove n clean n wire brush n reattach each n every cable n connection n try her. As posted a ground to a thin or wimpy rusty seat/batery box can also cause a problem. If when you try n crank her the lights dim way down badly and the battery voltage drops drastically (sounds like whats happening to you) Ima thinkin the switch is okay so its a starter problem like worn bushings or an armature at fault....If the cables n battery??? n starter switch are alllll llll okay Im afraid its the starter that needs attention...
John T
John T
03-22-2008 06:16:30
John T
Mike M
03-22-2008 05:46:37
Well after 58 years those starter bushings may be getting worn and letting the armature drag. Cheap fix if caught early. Very expensive after it's burnt up.
ET
03-22-2008 04:17:31
Check your ground conection where it hooks to the battery box. If the battery box doesn"t make a good ground conection to the rockshaft that can cause a problem. You may need to run a longer ground cable right to the tractor frame.
jd b puller
03-21-2008 19:27:16
 Re: 50B starter in reply to Doug Armstrong, 03-21-2008 18:07:25
do you have your petcocks open? Are they plugged?
johns48jdb
03-21-2008 18:29:12
not an expert, but they'll jump in soon. for now most say clean your connections and have you done something to the cables that is different. welding cable wire makes excelent battery to starter wire. have dealer hammer on lugs for the ends. if you can borrow his tool and after you have run your cable under the floor pan add the cable end. this will save you a bunch of headackes. maybe you've been reading the post on floor plan removal. i've found that to much oil on a starter is not a good thing. it may need removing and cleaning good and relubricating. i'll let pat, fit and john t help you from here.
