730LP Oil bath blew off
Ben.So.Tex
03-21-2008 12:06:33
I have notice oil leaking from the oil bath lately,and that the tractor sounds different like it has a burnt vavle or sticking vavle. I change the points and plug today to see if maybe they were fould or bad. Then took the tractor for a short test run about 2 football field lenghts and it blew the oil bath off. I am thinking it is time for a vavle job, This is a GOOD 730. Tractor is used and kept under a shed about 300+ day a year.
What do you folks think?
Rich Duane
03-21-2008 18:42:38
 Re: 730LP Oil bath blew off in reply to Ben.So.Tex, 03-21-2008 12:06:33
Some times we over look the obvious.Try checking the tapet clearance.It's posibale someone didn't tighten a adjusting nut and the adjuster tightened up.
Rich
2cylinderlp
03-21-2008 14:41:46
I agree with Frank and Mike. Generally LP engines are cleaner and less subject to wear, except the valves which are supposed to have hardened seats and rotators. An incedent like you describe was also why the distributor on LP tractors is set up differently, to prevent a back fire through the induction system.
Mike M
03-21-2008 12:34:35
A COMPRESSION TEST should reveal a valve problem.
You might also be getting too much gas pressure ?
F-I-T
03-21-2008 13:13:37
 Re: 730LP Oil bath blew off in reply to Mike M, 03-21-2008 12:34:35
A leak down test is handy, too in case you just want to hear where the leaking is.
Frank
