1957 JD 420w differential ring gear and pinion
Gary Rutz
03-21-2008 08:37:23
While plowing snow this winter, the differential ring gear gave out, loosing about half its teeth. I can't find a ring gear and pinion set any where. Anybody have any ideas?
buickanddeere
03-22-2008 16:37:28
 slant steer? HD RP no problem and cheap in reply to Gary Rutz, 03-21-2008 08:37:23
If your 420 is post 125,001 with the slant steer. Have no fear, a DH R&P is here cheap. Just use the R&P gears from a dime a dozen wrecked 1010 gassers prior to serial number 31,000. The R&P are much beefier and will squeeze into the 420/430/435 transmission case. The diesel 1010 R&P are a lower ratio/higher ground speed design. If you want to further slow the 420 down a 15% in every gear. Take the final drive gears from a post 31,001 1010 and bolt them in.
Mike M
03-22-2008 05:55:26
 Re: 1957 JD 420w differential ring gear and pinion in reply to Gary Rutz, 03-21-2008 08:37:23
That may be the same as in crawler models and I have heard of alot of 440's tearing out the ring and pinions.
Dave H
03-21-2008 18:50:14
Gary
I would think there would be a bunch of those around, but i donno. By the way you have not invented that trick, I beat you to it on my 58 420.
That is a wierd way of setting those things up with the cone angle if you have read up on it. I, with a little help figured out a way to rig up a guage/tool.
When that happened to me I called John Shepard 715-265-4988 and he fixed me up with a good used set. john also knows the scoop on the changes and maybe the chance of upgrading when you are in there. But I doubt if you would ever be able to wear one out, unless you are several decades younger than me.
Good Luck, If John doesn't have one I bet his neighbor will.
gary rutz
03-23-2008 11:32:04
 Re: 1957 JD 420w differential ring gear and pinion in reply to Dave H, 03-21-2008 18:50:14
Thanks Dave, I"ll give John a call monday and see what he can find.
