420u special equipment
Matt Fleisher
03-21-2008 07:35:24
I've just bought a 420u from a friend he had two cylinder research the serial number. I have a couple questions. What is this code CJ316? What front end should it have round tube or square? It has a standard front axle under it right now which I know is not right. Where to get parts, three point, drawbar assembly,hood,grille,seat frame and other stuff. Thanks for your help.This is my first 420, I'm familiar with A,B,G's
Matt Fleisher
03-22-2008 13:23:27
 Re: 420u special equipment in reply to Matt Fleisher, 03-21-2008 07:35:24
CPeter; It shows in the parts book, on a standard front axle the spindles are very tall. On a utility front axle, the spindles are short.
This tractor also shows signs of orange paint, and has a Kosch steering system on it.Some type of system that saves your arms from the snap of the steering wheel.It also has turf tires on it .Thanks MATT
CPeter
03-21-2008 13:03:00
What are you calling a "standard front axle"? An axle from a standard tractor? A 420U has an adjustable round tube axle.
CPeter
mikicic
03-21-2008 12:36:10
No one knows for sure what the description is for CJ codes. CJ stands for Custom Job,[special order at time of assembly] but the # is not known. We have a Orange 40U with code of CJ41. Posssibly was the paint color or special equiptment that was added at the time it was built. Yours might have been ordered with the standard front axle, and no 3-point, that could be the CJ code. You might want to leave the front axle the way it is. After all it has a CJ code.
