Gallons per hour/ mile
greenmisterg
03-20-2008 12:30:59
I have a 1951 G , I wondered if anyone knows how many hours/ miles driving over the road in 6th gear high reange I could go? There is a local show less than 20 mile from my house and I would want to try to drive it out there without towing a gas cart.17 gal main 1 1/2 aux ? tank...thanks!
fixerupper
03-20-2008 17:26:35
 Re: Gallons per hour/ mile in reply to greenmisterg, 03-20-2008 12:30:59
Used to haul corn to town 6 1/2 miles away with a 51 A. On a good day I could make four trips. If I remember right she got 6 MPG. Then I graduated to the 1086 (I was in heaven)and I could make six trips hauling twice as much per trip, but the mileage was still 6 MPH. We were putting about 1000 miles on the 1086 every fall.Jim
Will P
03-20-2008 13:26:22
I also have a 51G. Took it to a show about 15 miles. Took 1 hour and 20 minutes running 12 miles an hour in 6th. May have used 2-3 gallons at the most. She has WMW 90 thousands over gas pistons and a Johnson manifold feed by her 51 big nut carb.
Have fun!!!
Will
buickanddeere
03-20-2008 13:08:44
12mph on road for 20 miles. Say 2 hrs travel at most. A "G" working hard should not burn 4gph. So tolling along the road at 1-1/2 gph would take about 3 gallongs to drive to the show. You could almost make the trip on the small tank under ideal conditions.
F-I-T
03-20-2008 13:25:01
 Re: Gallons per hour/ mile in reply to buickanddeere, 03-20-2008 13:08:44
I would have guessed maybe 2 gph, since it's not all that efficient on gasoline if it still has all-fuel compression. I know if you pulled our '48 "A" with aluminum pistons hard on 3-14's, it would burn near 5 gph. That's what sold us on the 70D with its 2 gph and 1/3 more hp and a third more plow. And, back then, diesel was half the price of gas. 18.4 cents vs. 36 cents for gas was $1.34 an hour fuel savings, so at 3,000 hours you had a free tractor. Many, many 70D's were paid for on fuel savings alone. And you got the option of power steering and live hydraulics!
I wonder what the fuel consumption rate of that "G" running at fast idle is? I would think that if you took the fast idle consumption rate and increased by 50% you'd be in the neighborhood of no-load transport of the tractor chassis only. Only guessing.
Frank
55 50 Ron
03-20-2008 13:07:15
Most of the old Deeres run about 10-12 MPH in roadgear so you could make that trip in about 2 hours. Running with no load, I would think you could consider 3 gallons per hour as the max it would use, maybe a little less. No way would it run out of gas on that short trip. With about 18 gallons available full up you could run 50-60 miles one-way and be OK.
Mike M
03-20-2008 12:42:30
I'd say fill up and go for it and give us a full report afterwards. I have ran a model 70 pretty hard in the feilds for many hours on a full tank. I wouldn't think it should take too long to go 20 miles ?
