1950 JD G Low Hydraulic Pressure
WJ Greenlees
03-20-2008 12:03:21
Looking for knowledgeable advice on what to do about poor hydraulic pressure for My 1950 JD "G". I suspect the pump is wore out, but I have not ruled out weak relief valves in the Powr-trol box.
The pump on this tractor is a third party pump that mounts in between the governor and the distributor. It is a live pump and the PTO does not need to be engaged to have pressure.
Does any one out there know who can rebuild/replace a pump like this? If you have a good pump you'd sell please send a picture and indicate a price. Thanks for your consideration. --wjg
Mike M
03-20-2008 12:07:27
 Re: 1950 JD G Low Hydraulic Pressure in reply to WJ Greenlees, 03-20-2008 12:03:21
How much pressure are you getting ? Those were not that high pressure of a system to begin with.
2t2@ia
03-20-2008 12:35:35
 Re: 1950 JD G Low Hydraulic Pressure in reply to Mike M, 03-20-2008 12:07:27
Were they somewhere around 700 psi? Maybe some less.
Mike M
03-20-2008 12:39:18
 Re: 1950 JD G Low Hydraulic Pressure in reply to 2t2@ia, 03-20-2008 12:35:35
I'd have to check my books , but 700-800 psi is what I was thinking.
WJGreenlees
03-22-2008 20:15:29
 Re: 1950 JD G Low Hydraulic Pressure in reply to Mike M, 03-20-2008 12:39:18
I have not measured the pressure with a gage, but I know I can barely operate my JD front-end loader of similar 1950's vintage. The loader struggles to pull your average 6-inch wooden post out of the ground.
