630 work in progress
wdct630
03-19-2008 18:28:40
third party image
third party image
just wanted to post a pic of what i have been working on this winter
fordtech
03-22-2008 09:23:20
 Re: 630 work in progress in reply to wdct630, 03-19-2008 18:28:40
If you dont mind me asking how much money do you
think it will end up in the end, I have a 630 that the engine is apart now and am consitering
doing a complete restoration on it but its turning into a money pit might just part it out!
wdct630
03-22-2008 18:59:14
 Re: 630 work in progress in reply to fordtech, 03-22-2008 09:23:20
prop 5500.00 thats no labor new psterring seals
govonor gasket kit engine gasket kit trans gasket kit
pto clutch discs pto pump seal rear end pto seals pistons rings
piston pins and bushings
rod and main bearings all bushings for seat
seat shock
exhaust valves and seats machine shop bill was 1200
didnt touch the trans rear end powr trol
clustch carb
starter
gen
power steering pedistal
tires wheel bearings govonor air pump
water pump radiator
and forgot some stuff iam sure but this tractor has sentamental value been on th farm since she was new and with the power ateering and 3 pt hitch its useful on a daily basis
gerard adinolfi
03-20-2008 18:20:54
wow ,looks like a new tractor ,great job.did you go to school to do that kind of work?
wdct630
03-21-2008 15:01:14
 Re: 630 work in progress in reply to gerard adinolfi, 03-20-2008 18:20:54
are you that guy that pulls a john deere 1650 and wins all the time with it and works at that john deere dealer and u have a ton of ihs and say u dont like john deeres and u mouthed off to a guy once at the orange fair and his little deere 530 pulled you super mta around like a toy
Mike M
03-20-2008 05:48:24
Looking good !
Looks even better now that I see you do have some screw jacks on both sides. Monitor here at work is better than at home I guess ?
DeereValley
03-19-2008 19:27:31
Looks great. What kind of paint did you use?
wdct630
03-19-2008 19:31:40
 Re: 630 work in progress in reply to DeereValley, 03-19-2008 19:27:31
john deere classic green
Andy Kavanaugh
03-19-2008 19:05:00
Looks like your restoration is doing real nicely. I hope to restore a 630 someday, I think they are the prettiest 30 series tractor. What is the difficulty level on one of those??
wdct630
03-19-2008 19:24:44
 Re: 630 work in progress in reply to Andy Kavanaugh, 03-19-2008 19:05:00
i would have to say fairly easy i think it $$$$$ parts are not cheap pistons are over 500 just pistons
BushogPapa
03-20-2008 21:20:26
 Re: 630 work in progress in reply to wdct630, 03-19-2008 19:24:44
The best time is after it is all broken in and able to be loaded down on a plow..!! 4x14" would be a nice balanced load for it.. I plowed last year with 4x16" F-145 semi-mounted and it had plenty power to pull that..just had to add ballast.. But, it took 2 years of easy use to get the engine broken in enough to actually "Work" it hard..the new mains were just a "Tad" tight..!!
