3020 diesel utitily
capt-ugly
03-19-2008 18:05:32
i have a 3020 diesel to restore; what is the oil presure recommened too be ??? the gauges shows about 26 lbs ! ????
capt-ugly
03-20-2008 14:35:36
 Re: 3020 diesel utitily in reply to capt-ugly, 03-19-2008 18:05:32
thanks i'm going to check on it right now !! thanks again !!
MSM
03-20-2008 06:25:32
30 pound at high idle with the tractor at operating temperature
K.B.-826
03-19-2008 22:19:27
What speed are you checking it at? Are you using a known good guage? If that's at full throttle with hot oil, it's a little on the low side. I don't have the exact spec in front of me, but I know that when everything is right they'll run about 40 psi wide open and mabey 20-25 at idle, when hot. Look on the right side of the engine, you'll see a square cover, with the tach cable coming off of the top. This is the oil pressure regulating valve housing. If you have an early 3020, there will be a screw sticking out of the cover, with sort of a hex shaped cap threaded on over it. Remove the cap, loosen the locknut, and turn the screw inwards. This should raise your oil pressure. On a later 3020, there will be no screw and you need to remove the cover and add shims under the spring. If you can't get decent oil pressure by adjusting, you may need to dig a little deeper. There's an o-ring between the oil filter canister inside the pan and the oil pump that can go bad, there's plugs in the ends of the rocker arm shaft that can leak, and also the possibilty of a worn oil pump, and of course worn bearings.
