4955 powershift problems
moe5020
03-19-2008 17:32:19
I have a 4955 and it doesn't back up. In reverse neutral
B1-100psi
Cl0-90psi
B3-15 psi
Then when you shift in to any other reverse gear all three of them elements shift to 30 psi and neither C1 or C2 engage. All the forward gears are ok but its jerky when Clo is engaged figure it might be the accumulator.
I just wondering if anyone has any thoughts or common problem over the years.
mattd
03-19-2008 18:25:21
 Re: 4955 powershift problems in reply to moe5020, 03-19-2008 17:32:19
definately a leak in the b3 oil circuit. likely is piston seals. what is the pressure at the sys press port on clutch valve housing. should be at least 180. if pressure at all other elements is the pressure at the sys press port when b3 is not engaged and when b3 is engaged pressure goes down then it is with the b3 oil circuit. take the shift valve housing off. behind it will be the oil passages. i cant remember which one is for b3, i will do some looking. but use shop air with a blowgun and pressurize that port with air. it should kick back, but if you hear air leaking then pull the brake pack.
44 Diesel Tech
03-30-2008 06:47:16
 Re: 4955 powershift problems in reply to mattd, 03-19-2008 18:25:21
Your answer is correct Mattd.
Howard
mattd
03-19-2008 18:48:42
another thing i thought of was the forward/reverse valve. it could be leaking, ive never seen that before but its possible. there is no shift valve for b3 it gets its oil straight from the the forward/reverse valve. maybe someone else might know which port behind the shift valve housing is for b3. i dont have a 15 speed book here.
