Floor pan screw removal???
davebr
03-19-2008 14:22:05
Hoe the heck do you get these out. These are the screws holding the floor pan on a 48 B, I need to replace the battery cable. Any ideas?
thanks,
Dave
sgt bull
03-20-2008 12:36:44
 Re: Floor pan screw removal??? in reply to davebr, 03-19-2008 14:22:05
heat 'em up to red, walk away. come back later and they'll come right out.
Rich Duane
03-19-2008 20:12:56
I took a 1/2" drive blade socket from Sears and reground the tip to fit a new screw and then proceded to remove the screws in my"A"&"50"and replace them with out marking the heads up.
Rich Duane
davebr
03-19-2008 16:51:58
 Thanks Guys, I got'em out in reply to davebr, 03-19-2008 14:22:05
I chose the weld flat washer then nut. Worked great.
Thanks Again for all the help
Dave
Tom -730
03-19-2008 16:49:23
I have done this a couple times, I had good luck with a hand held impact driver. Got a 1/2 inch drive slotted bit at Napa. When I put new ones in, they were allen style from a John Deere corn head. Lots easier to get out next time.
Mark-IA
03-19-2008 16:46:01
Heat them red with a torch and let them cool. They will screw right out.
donwisc
03-19-2008 16:03:51
If you have access to a impact wrench use a socket driven large flat blade screw driver, it will be out in 5 seconds
johns48jdb
03-19-2008 15:57:13
a word of caution. the holes are open ended and anything loose that comes off the screws will fall into the rear end. this is probably where a lot of water got into rear ends over the years. use a good sealer when you go back with the screws and don't leave it parked out where rain can settle around the screws. if you have to leave it out you might want to consider drilling a drain hole in the pan where the water will run out and not puddle around the screw heads.
55 50 Ron
03-19-2008 17:15:27
 Re: Floor pan screw removal??? in reply to johns48jdb, 03-19-2008 15:57:13
Maybe the holes are open ended on some models but I don't think that's true on all of them.
F-I-T
03-19-2008 16:41:25
John:
Are you sure about that? I don't seem to recall those being drilled through.....I just had the platform off of my 70D and those were blind. I think that's why they seem to rust in place so easily. Not a big deal as you should always sealem 'em up proper.
Frank
johns48jdb
03-20-2008 19:41:55
 Re: Floor pan screw removal??? in reply to F-I-T, 03-19-2008 16:41:25
hi fit, putting the b back together today and mounted the power trol housing yesterday and forgot to put the battery cable back in its groove so it was either take the battery cable loose of take the floor pan out. i took the floor pan out, i had put some black rtv on them when i replaced them in 99 and with a little work they came out. unfortunately i broke a allen head socket off trying to get one off with a ratchet. i used a pipe wrench on the socket and had the guy helping me use a punch to hit down on the broken socket as i pulled. it finally gave up and came off. yes, the holes do go all the way through to the rear end on my 49. i thought they did. i felt it was funny that we were talking about this very subject on here and today i had to do it. i added a note on johnnny popper web site tonight on the happenings today. i will add a detail break down on my cost and problems on replacing the seals and felt washers this wek end. i hate it when alot of people ask questions and never come back and say yeah, i fixed it by doing this or that and thanks for the help. i have apprecaited all your help on my seals and felt problems.
Larry in WNY
03-20-2008 09:16:03
On my JD 60 the bolt holes were through. I haven't checked but they may be the same on a JD 620. On our JD 720D the platform screws are not through - same as Franks's 70D. It seems to vary by model.
Larry
davebr
03-19-2008 19:41:42
Just FYI, on this 48 B they are through holes.
2cylinderlp
03-19-2008 15:22:52
I found it easiest to weld a large washer to the screw, and then welded a nut to the washer.
LarrySTN
03-19-2008 15:21:33
weld nuts to them. Use a large nut and weld inside the nut to the screw, this will concentrate heat to the screw without warping the floorboard. Sometimes this procedure will need to be repeated until the screw gets heated enough. Works best with a wire welder.
wdct630
03-19-2008 14:38:41
restoreing a 630 need heat heat and more heat turn them nice and cherry red and chisel them out then got new ones from deere .55
F-I-T
03-19-2008 14:45:51
 Re: Floor pan screw removal??? in reply to wdct630, 03-19-2008 14:38:41
I have welded a nut to them as well. Use some Nev-R-Ceez on the new ones after cleaning the bore with a tap.
Frank
The JD Workmen
03-19-2008 14:29:33
To remove the floor pan screws we used an air chisel to help break it loose.
Dan in Ohio
03-19-2008 16:08:32
 Re: Floor pan screw removal??? in reply to The JD Workmen, 03-19-2008 14:29:33
The air chisel worked well for me too. Fast and reatively easy.
