I am looking to Rewire my 48 B
davebr
03-19-2008 13:51:16
Can you guys tell me if I am wrong? I am rewiring to 12 volt neg. ground. Generator is already converted with voltage reg. attached. Here goes: View is from back of gauges.
1) Positive cable from bat to starter, Neg to ground.
2) "+" side of Amp gauge side to starter.
3) "-" side of amp gauge to Left side light switch
4) "-" side of Amp gauge to "BAT" on regulator.
5) "F" on regulator to "F" post on generator
6)"GEN" on regulator to "A" post on generator
7)"-" post on coil to distributor.
8)"+" post on coil to left side of key switch.
9) Right side of key switch to left side of light switch.
10) Right side of light switch to lights
Is this correct? Am I missing anything? Remember, 12 volt negative ground. Do I have anything wrong?
Any help will be greatly appreciated. I have diagrams but the do not specify 12 volt neg ground.
Thanks,
Dave
johns48jdb
03-20-2008 04:49:08
 Re: I am looking to Rewire my 48 B in reply to davebr, 03-19-2008 13:51:16
am i missing something. did he say he was making it positve ground? is that right for a 12 volt system?
PBrowning
03-19-2008 14:24:49
Dave -- Go to the JD-H Site (below) and scan across to ARTICLES 2. From the drop-downs, see WIRING DIAGRAMS 3, and then under that one go to JD-B and print out a full-size version of your tractor's wiring diagram -- makes a good add to your manuals. (PatB)
davebr
03-19-2008 14:44:36
 Re: I am looking to Rewire my 48 B in reply to PBrowning, 03-19-2008 14:24:49
Hey Pat, thanks for the reply. I did do that a few days ago. The diagrams are not exactly the same as my system ie.. coil, Regulator posts (i have F, GEN, and BAT on mine, this diagram has L, BAT, and F). I can assume L in GEN? And looking at the diagram of the instrument pane, what is the wire from the + side of Amp gauge and the wire from the top of the light switch, they look as if connected to something??? Is the diagram for serial number B2001000- 12 volt? Remember mine is being converted to neg ground. I just want to get it right.
Thanks,
Dave
John T
03-19-2008 16:03:18
 Re: I am looking to Rewire my 48 B in reply to davebr, 03-19-2008 14:44:36
Dave, if you only have a 3 terminal (BAT ARM FLD) Voltage Regulator it can still work where it used to have a 4 terminal (LOAD BAT FLD ARM) buttttt ttttt you have to wire it different.
On a 3 terminal VR loads like lights n ignition are fed hot battery voltage from the Load (NOT battery/starter) side of the ammeter..... .Thats the same ammeter terminal that wires to BAT on the VR. The other Supply ammeter terminal wires to the hot ungrounded battery post often at the starter switch where the big battery cable is attached.....
On a 4 terminal VR those same loads were fed instead form the L terminal on the VR NOT from teh Load side of the ammeter.
Loads still need voltage to operate so on a 3 terminal VR (NO L terminal) they are fed off the load side of the ammeter
3 terminal Vr wires
BAT to load side of ammeter ARM/GEN to Gennys ARM post FLD to Gennys FLD post
John T
davebr
03-19-2008 16:42:22
 Re: I am looking to Rewire my 48 B in reply to John T, 03-19-2008 16:03:18
I will admit that I suck at wiring which is why I want to be clear. So what is the load side of amp gauge? And if you do not mind what are the corrections to my plan of wiring?
Thank you very much for responding.
Dave
Mike M
03-20-2008 06:05:24
 Re: I am looking to Rewire my 48 B in reply to davebr, 03-19-2008 16:42:22
I have had ampmeters that worked opposite of others. Sometimes if you go by the + or - on the face it works out sometimes it doesn't. Depends on how it is made inside the meter. Then you just need to swap them around.
If going from a 4 term. reg. to a 3 term. you can hook the BAT. wire and the wire that goes back to feed the lights on the same BAT. term. at the regulator. Not sure if this was mentioned before in other answers ?
John T
03-19-2008 17:10:11
As you have it wired thats (Load side) the ammeters - terminal. Since it feeds hot battery voltage to the switch (for ignition or lights) that Load side of the ammeter should have a wire from it over to the BAT or Input terminal on the switch. That same - Load ammeter terminal wires down to BAT on the VR. Sounds like you pretty well have it correct, be sure and Polarize the Genny BEFORE you start her up. If the ammeter reads bass ackwards it simply needs its wires reversed/swapped from one side over to the other.
Heres a link to M Mans diagrams, your B just has the battery polarity reversed
Link
PBrowning
03-19-2008 15:08:53
Oh yes -- now I recall. Be Blessed!
davebr
03-19-2008 15:13:00
 Re: I am looking to Rewire my 48 B in reply to PBrowning, 03-19-2008 15:08:53
So what do you think? Have I got anything wrong or backwards?
Thanks for the help?
Dave
