46b a back a firin
patsdeere
03-19-2008 09:29:02
I have a B that will backfire occasionally. It isn't consistent (which makes it even worse). It might run great for a minute then backfire, run good for 20 seconds and backfire again. I have tried to adjust the timing both ways and it just made it worse. Since it has all new valves, seats, and rings, will it go away after the breakin period or is there something out of adjustment that I am not thinking of?
As always, Thanks.
DanL-B36320
03-19-2008 15:31:31
 Re: 46b a back a firin in reply to patsdeere, 03-19-2008 09:29:02
Valve lash adjustments, maybe?
John T
03-19-2008 12:34:09
I wonder if theres some vacuum leaks such as the carbs throttle shaft bushings and/or the carb to manifold gasket or the manifold to head gasket?? At idle if you spray WD 40 or carb/choke cleaner around those areas n she speeds up or smoothes down you found a vacuum leak. As far as ignition Id be checking the cap n rotor for cracks or carbon traces or moisture and inspect the plug wires n plugs. Is the ignition in pretty good shape as far as points n condensor??
John T
patsdeere
03-19-2008 22:08:35
 Re: 46b a back a firin in reply to John T, 03-19-2008 12:34:09
I'll try the spray and see if it helps. Everything in the way of ignition is new (wires, cap, etc).
Mike M
03-19-2008 09:38:23
Too lean of mixture or a ignition problem will usually be the main causes of backfireing. So how does it run otherwise under a load ?
patsdeere
03-19-2008 22:07:20
 Re: 46b a back a firin in reply to Mike M, 03-19-2008 09:38:23
It sounds the same whether under load or not. I tried playing with the carb and it didn't seem to make much difference.
PBrowning
03-20-2008 09:49:16
 Re: 46b a back a firin in reply to patsdeere, 03-19-2008 22:07:20
Here's the site URL. See the last item on the last page. (PatB)
Mike M
03-20-2008 06:11:19
Have you tried the no wrench carb. test over at jdhpubs.com ? might be a good starting point to see if a passage is plugged up.
