JD 1010 water in oil
MICHAEL WILDER
03-18-2008 18:39:52
My JD 1010 (sn#RUS 46792) has been sitting up for most of the winter, so I went to put water in the radiator and it ran right through. I pulled the radiator and found a freeze had got to it. I reinstalled the radiator after the repairs were made and started to refill. After putting in 6 gallons, and wondering where is all this water going, it started coming out of the ventilator outlet tube. I opened the drain for the block, water came out for about 1.5 gallons then an oil mixture. i pulled the dip stick out and mostly pure water poured out. So, the big question now is this worth fixing, is it just the o-rings and head gasket like I've read in the archives?
MICHAEL WILDER
03-26-2008 15:10:28
 Re: JD 1010 water in oil in reply to MICHAEL WILDER, 03-18-2008 18:39:52
I pulled the oil pan, and it does look like the leak is coming from the cylinders. I'm finding several gasket kits; head, conversation, upper, lower. Can you tell me which kit i need, and will include the o-ring or 'back-up ring' as JD parts refer to it? Or can i just get away with the head and cylinder gaskets ( and now oil pan )?
jdemaris
03-19-2008 05:56:10
1010s and 2010s have only has one seal per sleeve which isn't much. All other Deeres now use three per sleeve. Often, with an older engine - if it gets drained of coolant and sits empty for awhile - whatever is left of those seals falls to pieces. I've seen it happen many times.
And yeah, you could have freeze damage also. Pull the oil pan, put coolant into it, and watch where is comes out.
MEWilder
03-20-2008 05:42:34
 Re: JD 1010 water in oil in reply to jdemaris, 03-19-2008 05:56:10
Thanks, I plan on pulling the pan today, I'll let you know.
K.B.-826
03-18-2008 21:17:14
You said that your radiator froze. Same thing probably happened to the engine block. You'll need to pull the oil pan to see if you can tell exactly what happened.
MICHAEL WILDER
04-04-2008 12:42:51
 Re: JD 1010 water in oil in reply to K.B.-826, 03-18-2008 21:17:14
I pulled the value cover off yesterday, and to my dismay the cylinder head has a crack and metal lifted up between the valves on cylinder #2. Is this cylinder head toast or can it be repaired? Not sure how deep the crack is or if it can be welded. Do you think this is worth repairing/replacing or should I just part it out and move on? I am getting close to having more in it than it's worth; new rear tires and rims, new carb, new water pump, the radiator has been recored, it's starting to look like a money pit.
