720 power steering
tomtractor61
03-18-2008 18:27:32
I am asking for a neighbor who has a 720 diesel. He is getting engine oil mixed in the power steering fluid. Anyone know where it could be coming from?
Dan in Pa
03-19-2008 10:13:00
 Re: 720 power steering in reply to tomtractor61, 03-18-2008 18:27:32
Had the same problem with my 520, new pump seals fixed the problem. It's a time consuming job cause you will have to loosen the radiator and lean it forward to remove the fan and pump. Don't try it any other way. BEEN THERE DONE THAT.
gpuller
03-19-2008 08:09:34
My 720d was doing the same thing. It would run for a while then oil would start coming out the power steering filler/vent. First the vent was cleaned and that didn't fix the problem. Finally figured the pump was sucking oil from the governor housing through the fan shaft. Pulled the power steering pump, replaced all seals, that did the trick.
That also made me wonder about all the talk about having to use Deere power steering fluid, or it will damage the system. It ran for 2 years with engine/power steering fluid mix. When it went back together I did flush the system and used the correct fluid.
Bigblock
03-19-2008 04:02:41
That may be why there are two seals facing each other.
F-I-T
03-19-2008 08:23:21
 Re: 720 power steering in reply to Bigblock, 03-19-2008 04:02:41
That's the idea. The two seals face each other to prevent fluid from moving in either direction. In the original seal, it was a double chevron design, with two internal lips facing in opposite directions, but that seal has not been available for years, so they revised the parts manuals for the two seal installation. To my knowledge, the only parts book that show that revision in a picture is the 520 parts manual. The exploded view shows the two seal version. In order to make up for the lost thickness of the old seal versus two newer thin seals, you installed a washer in between them as a spacer between the two on the fanshaft side.
Frank
third party image
RobMD
03-18-2008 19:53:22
Are you sure? are you absolutely positive? oil CAN go FROM the power steering pump shaft seals INTO the engine through the fanshaft... EVEN though I have heard of oil coming from the engine TOWARDS the fan, i've never really thought about it being sucked up by the power steering pump.
44 Diesel Tech
03-30-2008 06:56:37
 Re: 720 power steering in reply to RobMD, 03-18-2008 19:53:22
Sorry Rob, F-I-T is right on this one. Howard
