jdemaris -- update on 2520D making oil
SWMO Chris
03-18-2008 17:45:03
jdemaris my 2520 has the following CB pump CBC431-4AL. You had mentioned in my previous post that you might be able to help me out with this info.
Mel in SW Iowa
03-19-2008 08:46:34
 Re: jdemaris -- update on 2520D making oil in reply to SWMO Chris, 03-18-2008 17:45:03
I have never worked on this problem, but if I did, I would Call Midwest Diesel Injection
2773 200th Street; Fort Dodge, Iowa 50501;
515-576-5601 and ask for Lee, the owner. He has solved injection pump problems for me for a reasonable price, and included some invaluble coaching as well.
Good Luck,
Mel
jdemaris
03-19-2008 06:15:39
CBC uses a coventional oil seal on the pump drive-shaft. It varies a little between the CDC and CBC. Some use a one-piece seal with dual sealing lips, and some just use two separate seals installed against each other. That is totally different that the dual umbrella-seal setup used on DB or JDB pumps. The CBC has to come off, then you remove a few bolts and remove the aluminum seal housing from the front of the pump. Put a new seal in - and put back together.
You can buy a compete seal kit from Ralph's Diesel - call 315-655-3702.
third party image
third party image
third party image
Mike M
03-19-2008 06:23:52
 Re: jdemaris -- update on 2520D making oil in reply to jdemaris, 03-19-2008 06:15:39
Did you see the update to the other post where he called that pump shop and they said all the parts were sold off and they don't fix those anymore ?
jdemaris
03-19-2008 06:46:52
 Re: jdemaris -- update on 2520D making oil in reply to Mike M, 03-19-2008 06:23:52
No, I didn't see the update - but regardless, it's not true. I just spoke to them a few days ago (at Ralph's Diesel).
Unless old Ralph died since then - they do still work on those pumps. I've given this warning before - you have to be careful who you speak to on the phone.
The problem is this. Ralph senior owns the shop and got his start inside a large Deere dealership in Cazenoivia, NY. He later moved out on his own. Ralph senior does the older Deere stuff. He has younger guys working there that specialize in automotive modern injection equipment - one is his son. Now, when you call - one young guy will be fine and tell you he can fix most anything on the C pumps. But, if the other guy gets on the phone - he'll just tell you they're are obsolete and won't touch it. If you get that guy - you have to ask for Ralph senior. Like I said, I just recently called them about this.
Seems to be a funny way to run a business - but - no matter where you go - you sucess depends on the person you actually deal with. The guy I spoke to last week - Ralphs son I believe - assured me they have the seal kits, and also new trottle-gear kits for those pumps. I have them here also, but mine are scattered and loose in a 5 gallon bucket - I've been saving them for close to 30 years.
Mike M
03-19-2008 07:39:41
 Re: jdemaris -- let's try a copy ? in reply to jdemaris, 03-19-2008 06:46:52
yes, its a c pump. called ralphs diesel and as predicted i got the grouchy son and he told me they absolutly do not work on c pumps any more. they sold all the tools and parts to another man in newyork, cunningham lumber he thinks, but not sure. any ideas for the roosamaster?
jdemaris
03-19-2008 08:02:34
 Re: jdemaris -- let's try a copy ? in reply to Mike M, 03-19-2008 07:39:41
I just called and got old Ralph on the phone. He says he is no longer going to work on C pumps and only sells the conversion kits. The buck stops at him - and I have no idea why the younger guy (Mike) told me differently.
That's that I guess. Maybe I'm the only person around with any parts? I fixed many over the years since the late 1960s, and often would open a new governor, throttle, or seal kit - and then throw the remaining new parts in a bucket. It still sits up on my shelf. I picked through it several times and sold off parts to people that were stuck - now maybe I ought to hang on to what's left? There are still an awful lot of Deere tractors around with those pumps on them.
Mike M
03-19-2008 09:27:28
 Re: jdemaris -- let's try a copy ? in reply to jdemaris, 03-19-2008 08:02:34
You may be the only one left with any parts and knowledge for them too ? Once there gone there gone. You may be able to start makeing some BIG money doing restos on those pumps since 4020's are getting collectable and HIGH dollar and these collectors seem to need everything right back to the way they left the factory.
jdemaris
03-19-2008 11:47:47
 conversion pump kit in reply to Mike M, 03-19-2008 09:27:28
It doesn't make sense to spend much money on those pumps. Fixing minor things, yes. But, if anything major a person is way ahead to put the conversion kit on and use the current JDB pump. Deere still sells kit - and it doesn' hurt the looks of the tractor. In fact, in most cases - how would you tell the differnce? Many 20 series tractors came new with the better pump anyway.
jdemaris
03-19-2008 07:49:20
I called there once and got the same guy - although I have no idea if he's one of Ralph's sons or not. He basically said the old pumps are crap, they are obsolete, and they don't work on them. I suspect he's a guy that never works on tractor stuff anyway - old or new. I called back a week later and got another young guy on the phone - and he was friendly and told me that do indeed work on them. I then told him about the previous phone call and he acted as if he had no idea who told me that.
So, I don't know what to say? I've known Ralph Senior since the late 1970s - when he was working at the Cazenovia Deere dealerership - and I was working at the Oneonta Deere dealership.
Maybe I'll call again and see if I can get old Ralph on the phone - if he hasn't croaked.
Mike M
03-19-2008 07:58:06
 Re: jdemaris -- let's try a copy ? in reply to jdemaris, 03-19-2008 07:49:20
Maybe that other guy has a dual personality ?
Mike M
03-19-2008 07:32:28
 Re: jdemaris -- update on 2520D making oil in reply to jdemaris, 03-19-2008 06:46:52
I think he said it was Ralph's son he talked to. Yes; That is a funny way to run a business. I have found local pump shops act funny too.
