If you close the load needle when it's running at half speed and the governor opens the throttle enough to call for fuel from the load passages it will die! That's because while it was running primarily on the idle circuit you shut the fuel delivery down too lean for it to run via the load passages. When it misses and you're doing this, the governor will open the throttle to speed it back up and once it gets open far enough to call for fuel from the load circuit, it will be fuel starved, will quickly move to WOT and die with nary another putt! You can only close the load needle without killing the engine if the throttle plate is never allowed to open enough to demand fuel from the load circuit. Since your tractor is as you say not idling correctly, when you shut down the load circuit, you make it so the engine can't recover from an idle mode misfire which you alread know it is going to do. I've cleaned and worked on and repaired many DLTX carbs and all I can say is get ALL of the passages fully opened up. That includes the back suction economizer passages and make sure the bowl gasket seals the fuel bowl. Even then a mid series A (especially if it still has all fuel pistons) may tend to lope and miss at slow idle settings. Also use a timing light to check your run timing to make sure it isn't too far advanced. Not uncommon! An all fuel sparking at 40� BTC with the throttle at slow idle may not have enough pressure built up in the chamber to fire reliably that early. Under load it may fire and lug right to the last putt but maybe not so at idle. Hope that helps some.
