720 transmission assembly
russell g.montg
03-18-2008 13:57:38
I am putting the 720 back together again after dissembling the sliding gear shaft and putting a new bearing in the right side of the shaft hole. I was wondering is there a way to check to see if the countershaft is in spec. I would rather take care of this now than have to take the tractor apart again and is there a specific rule on when to change a bearing. The one on the right had not fallen apart but was wore enough to make the shifting difficult. The left bearing seems tight but how do you check wear. I have pulled up and down on the countershaft and it seems pretty tight. Thanks for the help. Russell
Mike M
03-19-2008 09:35:48
 Re: 720 transmission assembly in reply to russell g.montgomery, 03-18-2008 13:57:38
Check the lower counter shaft by just pulling in and out on it. spec. is to be .001"-.004" end play
and also check the lock nut and see if it is tight too. Very hard to find one that is not way too sloppy. You really have to pull the lower bearing out and have a look at them to see that they are not flakeing out. I don't think I have ever went to all the work to do the top shaft without not pulling the bottom one too as you are right there. I have seen WAY too many bad ones.
russell gmontgomery
03-20-2008 13:42:12
 Re: 720 transmission assembly in reply to Mike M, 03-19-2008 09:35:48
thanks mike ill take out the countershaft to inspect the bearings. Thanks, Russell
